- #176
Dale
Mentor
- 35,628
- 13,985
Nonsense, it doesn't invalidate anythying.Samshorn said:And do you understand that this invalidates all your claims?
a=t/T is unitless, it does not have units of time. No matter how many times you assert that it is time, the assertion is false.Samshorn said:it is simply a re-scaled coordinate time, a = t/T
I never said otherwise. In fact, for the lab particles I very clearly said [itex](t,r,\theta,z)=(aT,R,0,0)[/itex] so obviously I intended from the beginning for t=aT. For the cyclotron particles [itex](t,r,\theta,z)=(aT,R,a2\pi,0)[/itex] so t=aT and θ=a2π. In all cases, a is nothing more nor less than a unitless variable which parameterizes the worldline.Samshorn said:Now that you admit that this, and hence that 'a' does not represent anything other than t/T where T is an arbitrary constant
And that is my point. In order to make your claim you have to go back and re-do the analysis differently from how I did it. I never said that you couldn't derive gamma (in fact I said the opposite many times), I only said and demonstrated that it is not necessary to do so. Certainly, if I went back and did the analysis differently than I did, I could come up with gamma. That doesn't alter the fact that doing the analysis the way I did never used gamma, even in disguise. To make that claim you are having to go back and do a different (but equivalent) analysis than what I did.Samshorn said:go back and re-do your analysis ... Get rid of the obfuscational 'a' and T
Beta is unitless, v has units of speed, therefore beta is not a re-scaled v. If beta were a rescaled v then it would have units of speed and you could not subtract it from 1.Samshorn said:Utter nonsense. If we define beta = v/c, it is unitless, whereas v has units of velocity, but obviously beta is just a re-scaled v.
Sure, with the understanding that you can always add some power of c back into make the units work out. There is no power of c that you can add to a in order to get it in units of time.Samshorn said:In fact, by choosing units so c = 1 we often write beta as just v, recognizing that it is a dimensionless version of velocity.
And so is continuing to harp on a minor notational mistake when:Samshorn said:Now, that is really unfair, isn't it?
1) I admitted immediately that it was a mistake
2) it makes no difference at all
