Lorentz Transformations in xy & xyz Directions | Pat
Lorentz transformations for inertial frames moving in the x-direction are straightforward, with y' and z' remaining unchanged. However, when considering motion in the xy or xyz directions, the transformations become more complex and involve additional parameters. The discussion references a paper by Byron L. Coulter that addresses relativistic motion in a plane, suggesting that the transformations can be derived using a more generalized approach. Matrix multiplication can also be used to express these transformations, incorporating the relative velocity vector. Overall, the transformations in multidimensional motion require a more intricate formulation than the standard equations for one-dimensional motion.
patapat
So I'm looking at some Lorentz transformation equations and it says
x'=\gamma(x-vt)
t'=\gamma(t-vx/c^{2})
y'=y
z'=z
I'm assuming the values for y', y, z' and z only hold true when the inertial frames of S and S' are moving at a relative velocity in the x-direction. With this being said, what would the transformations be if the inertial frames were in an xy or xyz direction? Thanks in advance.
-Pat
lorentz transformation plane motion
x'=\gamma(x-vt)
y'=y
z'=z
-Pat
As far as I know the situation is known as plane motion. Your question is answered in
Relativistic motion in a plane
Byron L. Coulter
Am. J. Phys. 48, 633 (1980) Full Text: [ PDF (486 kB) GZipped PS Order ]
I think it can be simplified.
x'=\gamma(x-vt)
y'=y
z'=z
-Pat
If (\mathbf{r},t) are space-time coordinates of an event in the reference frame O, and the reference frame O' moves with velocity \mathbf{v} = c \vec{\theta} \theta^{-1} \tanh \theta with respect to O, then space-time coordinates (\mathbf{r}',t') of the same event in O' can be obtained by formulas
\mathbf{r}' = \mathbf{r} + \frac{\vec{\theta}}{\theta}(\mathbf{r} \cdot \frac{\vec{\theta}}{\theta}) (\cosh \theta - 1) - \frac{\vec{\theta}}{\theta} ct \sinh \theta
t' = t \cosh \theta - (\mathbf{r} \cdot \frac{\vec{\theta}}{\theta}) \frac{\sinh \theta}{c}
These formulas are derived by the same procedure as momentum-energy Lorentz transformations (see eq. (4.2) - (4.3) in http://www.arxiv.org/physics/0504062 )
Eugene.
t'=\gamma(t-{\vec r}\cdot{\vec v}/c^2)
The previous reply is three equations, I couldn't get Latex to do line by line.
r_\parallel and r_\perp are parallel and perp to v.
And if you know matrix multiplication,
B = \begin{pmatrix} \gamma &amp; -\gamma \beta_1 &amp; -\gamma \beta_2 &amp; -\gamma \beta_3 \\<br /> -\gamma \beta_1 &amp; 1 + \frac{(\gamma - 1)\beta_1^2}{\beta^2} &amp; \frac{(\gamma - 1)\beta_1\beta_2}{\beta^2} &amp; \frac{(\gamma - 1)\beta_1\beta_3}{\beta^2} \\<br /> -\gamma \beta_2 &amp; \frac{(\gamma - 1)\beta_1\beta_2}{\beta^2} &amp; 1+\frac{(\gamma - 1)\beta_2^2}{\beta^2} &amp; \frac{(\gamma - 1)\beta_2\beta_3}{\beta^2} \\<br /> -\gamma \beta_3 &amp; \frac{(\gamma - 1)\beta_1\beta_3}{\beta^2} &amp; \frac{(\gamma - 1)\beta_2\beta_3}{\beta^2} &amp; 1 + \frac{(\gamma - 1)\beta_3^2}{\beta^2}<br /> \end{pmatrix}
where \beta = (\beta_1, \beta_2, \beta_3) is a unit vector in the direction of the relative velocity, and
x&#039; = B x for x = (c t, x, y, z) and similar for the transformed system x&#039;.
Source: Jackson, Classical Electrodynamics, chapter 11.7[/size]
I had a feeling there was no simple answer, thanks guys.
  • · Replies 101 ·
  • · Replies 54 ·
  • · Replies 22 ·
  • · Replies 24 ·
