Special Relativity: Explaining 4Potential as a 4Vector
  • Thread starter Thread starter Llewlyn
    Potential
The discussion centers on the nature of the four-potential in special relativity, specifically whether it is a four-vector only in Lorentz gauge. It is established that the four-potential is indeed a four-vector regardless of the gauge used, as it can be transformed by adding a gradient of a scalar function. The invariance of the d'Alembert operator is confirmed, supporting the four-vector nature of the potential. Additionally, the continuity equation's scalar nature implies that the current density must also be a four-vector, although counterexamples are discussed regarding the transformation properties of certain tensors. Ultimately, the conversation emphasizes the importance of gauge invariance and Lorentz covariance in the context of electromagnetic theory.
Llewlyn
Let's speaking about special relativity.
A four-vector is a physical quantity with 4 components that, when passing from one inertial frame to another, transform those components applying the Lorentz matrix, as the event (ct, x, y, z) do. Now i define the 4potential as (\phi, \vec{A}). For being sure that IS a 4vector i have to change frame and show that the new 4potential is obtained applying the Lorentz matrix, but i don't know how to do it. So i put in Lorentz's gauge and write Maxwell equations that results to be:
\square A^{\mu} = j^{\mu}
where j^{\mu} is the 4current (that i know is a 4vec). So because the d'alembert operator is invariant, or rather, it doesn't change the algebra of the quantity applied it i obtain the 4vec nature of A^{\mu}. But...
1) Does the 4potential is a 4vector ONLY in Lorentz gauge? Because I've seen in 2nd quantitation that it has be used as a 4vec in Coulomb's gauge.
2) How can i proof that the d'alembert operator is "invariant"?
Really thank you for attention,
Ll.
\partial^\mu is a four vector. In order for the continuity equation to be a scalar, this requires j^\mu to be a four vector.
Since \partial^\mu is a four vector, the d'Alembertian
\partial^\mu\partial_\mu is a scalar.
The wave equation then shows that A^\mu is a four vector in the Lorentz gauge.
It's a 4-vector regardless of the gauge. Want to know how to prove it? Okay, I'll tell ya.
Start in the Lorentz gauge, where you already know that the 4-vec potential A_\mu is a 4-vector. Then change to a different gauge... and how to do this? Well, we know how... Introduce a scalar function 'f(x)' and in the new gauge the 4-vector potential is
A_\mu + \partial_\mu f(x)
Is this still a four-vector? Yes, because \partial_\mu f(x) is a four-vector and the sum of two four-vectors is a four-vector. Cheers.
In fact it is possible for \partial_{\mu} j^{\mu} = 0 to be true in all frames without j^{\mu} being a four vector. For example, there could be a 2nd-rank tensor T^{\mu\nu} that satisfies \partial_{\mu} T^{\mu\nu}=0. If you then define j^{\mu}:=T^{\mu 0}, we have an counter example.
Anyway, the current density j^{\mu} can be assumed to be a four vector for other reasons too.
This conclusion was logically valid, but I'll restate it for clarity:
"If we assume that the equation of motion is Lorentz invariant, then it follows that the four potential must transform as a four vector."
Alternatively we could draw the conclusion in the other direction:
"We postulate that the four potential transforms as a four vector, and therefore the equation of motion is Lorentz invariant."
Whatever you like. IMO the transformation properties of different fields are something that should be postulated, and the invariance of the equations are something that should be proven.
true. good example.
Of course, any tensor of all zero entries will have all zero entries in any frame and so then any subset I pick out to make up a "thing" will also always be zero in any frame. I think that perhaps Pam just misspoke--she must have meant to say, "... In order that the LHS of the continuity equation transform as a Lorentz scalar, j_\mu must be a 4-vector."
But isn't j^{\mu} =T^{\mu 0} also a 4 vector ? You have found no counterexample. If \partial_{\mu} j^{\mu} is a scalar, then j^{\mu} necessarily is a 4-vector.
No. It doesn't transform like
<br /> T^{\mu 0}\mapsto \Lambda^{\mu \nu} T_{\nu}{}^0,<br />
which would be a four vector transformation, but instead like
<br /> T^{\mu 0}\mapsto \Lambda^{\mu\nu}\Lambda^{0 \alpha} T_{\nu\alpha}<br />
This conclusion seems to be right on a quick glance, but the previous counter example makes one think more carefully. I suppose that it could be made correct by more rigor assumptions.
It could be that if it is a non-zero scalar, then j^{\mu} would have to be a four vector.
I'm afraid you're confusing things. To help out a bit: How many components does T^{\mu 0} have ? And how many will it have after performing a Lorentz transformation on its argument, "x" ?
Incorrect.
Do you know why energy is not considered to be a scalar?
bigubau said:
Yes, you're right. My bad.
Now you surprised me! :wink:
Actually, the vector potential cannot be genuinely a vector with respect to the Lorentz transformations as a massless vector must necessarily be given by the gradient of a scalar field of hilicity zero. But F_{\nu \nu} (which does transform as a tensor) is composed of two terms of hilicity 1 and -1.
Since F_{\mu \nu} = \partial_{\mu}A_{\nu} - \partial_{\nu}A_{\mu}, thus under Lorentz transformations A_{\mu} does not transform as a vector but is supplemented by an additional gauge term:
<br /> U( \Lambda ) A_{\mu}(x) U^{-1}( \Lambda ) = \Lambda^{\nu}{}_{\mu} A_{\nu}( \Lambda x ) + \partial_{\mu} \lambda ( x , \Lambda )<br />
So, there is no ordinary Lorentz-vector field for massless particles of hilicity \pm 1.
regards
sam
No, but the integral
\int d^{3}x T^{\mu 0}
is a 4-vector, if the tensor T is conserved, i.e., if
\partial_{\nu} T^{\mu \nu} = 0
regards
sam
Since F_{\mu \nu} = \partial_{\mu}A_{\nu} - \partial_{\nu}A_{\mu}, thus under Lorentz transformations A_{\mu} does not transform as a vector...
hmm. but if I want to get, say, the 4-vector potential in the Lorentz gauge of a uniformly moving point charge, I can start from the rest frame Columb potential A_\mu= (1/r, \vec 0) (charge chosen to be 1) and boost this in the normal way...
A gauge term is still necessary, since if
A_{i}(x) = 0
it follows that
UA_{i}(x)U^{-1} = 0
for any unitary transformation U. The structure of
UAU^{-1} = \Lambda A( \Lambda x) + \partial \lambda
guarantees that the gauge-invariant Maxwell equations are Lorentz covariant. Thus two Lorentz observers O and O' who construct in their respective frames a quantum electrodynamics in any gauge are assured of a unitary transformation relating the states of O & O'.
regards
sam
  • · Replies 29 ·
  • · Replies 53 ·
