2 Carts on a Track Compressed by a Spring -- What are their Velocities?
The total energy in the system is determined solely by the potential energy of the spring, calculated to be 7.8125 J. When the carts are released, their velocities were initially calculated separately, resulting in 4.616 m/s for the lighter cart and 5.33 m/s for the heavier cart. However, it was recognized that the potential energy of the spring is divided between the two carts, indicating that the initial approach was flawed. The discussion highlights the need to apply conservation of momentum alongside energy conservation to solve for the velocities accurately. This realization provides a clearer path to determining the correct velocities of both carts.
BlueLava
Two frictionless carts, with masses mA=43mB and mB= 0.55kg are on a level track. The carts have an ideal spring between them with spring constant κ= 250J/m2. The carts are compressing the spring a distance xi= 25cm from its equilibrium position.
Potential Energy of A Spring: U = 1/2 K x^2
Work Energy Theorem W = Change in K
a)What is the total energy in the system?
Only energy acting on the system assuming the track is level and there is no potential energy of the carts, is the potential energy of the spring.
Comes out to 7.8125 using the potential energy of a spring equation.
b) What are their velocities if the carts are simultaneously released?
This is what stumped me, initially I started by doing separate work energy theorems for cart A and cart B.
W = 1/2 ma Vf^2
7.8125 = 1/2(.733)vf^2
Came out to Vfa = 4.616
Using the same equation Vfb came out to Vfb = 5.33
That gave me velocities that made sense, the heavier cart(A) had a lesser velocity then b.
But then I realized, that potential energy of the spring is split up between the 2 carts, so setting that potential energy equal to work for both equations was probably incorrect. This is where I'm stuck.
Hi,
You already understand that the energy that is stored in the spring will be converted to kinetic energy of the carts and that the sum of the kinetic energies of the carts will be 7.8125 J. One relevant equation (energy conservation) used up. But there are two unknowns (the speeds) so another relationship (equation) will be needed. Know of any other variable (other than energy) that might be conserved ?
Oh, and, eh:
:welcome: !​
OH I see now that I might be able to use conservation of momentum to solve this equation.
Bingo !
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
