2 unit negative chargees and a positive charge +q are along the same
To achieve equilibrium among two unit negative charges and a positive charge +q, the magnitude of +q must be less than 2 units, specifically between 0 and 2 units. The positive charge should be positioned closer to the negative charges to balance the forces acting on it. The neutral point, where the net force is zero, will not be at the extreme left but rather between the negative charges and the positive charge. The exact location depends on the specific values of the charges and their distances. Understanding the balance of electrostatic forces is crucial for determining the equilibrium position.
partho550
2 unit negative chargees and a positive charge +q are along the same line. what should be the magnitude of charge q and in which position must it be placed so that the three charges remain in equilibrium...
where do you think will be the neutral point... will it be along extreme left?? kinda confused!
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 31 ·
