A 1130-kg car is held in place by a light cable on a frictionless ramp
A 1130-kg car is held on a frictionless ramp by a cable at a 31° angle, while the ramp itself is inclined at 25°. The discussion focuses on calculating the tension in the cable and the normal force exerted by the ramp. Participants clarify that the tension is related to the weight component parallel to the ramp's surface, emphasizing the importance of understanding the angles involved. The tension can be determined by balancing forces, with the parallel component of the weight equating to the horizontal component of the tension. The conversation highlights the need to visualize the forces accurately to solve the problem effectively.
mirs
A 1130-kg car is held in place by a light cable on a very smooth (frictionless) ramp. The cable makes an angle of 31.0° above the surface of the ramp, and the ramp itself rises at 25.0° above the horizontal.
a). Find the tension in the cable.
b). How hard does the surface of the ramp push on the car?
Newton's Laws of Motion
From my understanding, there are three arrows, one showing the weight of the car pointing straight downwards through the ramp, another is the normal force arrow drawn perpendicular to the surface of the ramp, and the third is the cable. The problem is, I don't understand where T=mgsin25 came from? How do I know which angle to use? Also, if this is the case, why is there a component of the car's weight parallel to the surface of the ramp? Then what is T?
That equation is just the force balance down the slope. What is the component of the weight down the slope?
I'm not sure, do you mean the component perpendicular to the surface of the ramp that goes downwards, or is there a weight component parallel to the surface of the ramp?
There is a weight component parallel to the surface. If there was no weight component in the opposite direction of the tension, the car would be pulled by the cable.
Try drawing the system at an angle, so that the surface of the ramp is flat, horizontal. Then apply your force diagram, with x being left/right and y being up/down. Just don't forget that the force of gravity is now down at an angle to the y axis, equal to the angle of inclination of the ramp.
Then go from there!
Oh ok! So the parallel component of the weight equals the horizontal component of the tension force in the cable? Would I then use this horizontal component to find the vertical component of T and then use basic pythagorean theorem to find the tension in the cable?
15K
20K
29K
30K
