A 4.4kg block is pushed along the ceiling
  • Thread starter Thread starter madelines
    Block
A 4.4 kg block is pushed along the ceiling with a constant force of 84.0 N at a 50° angle, resulting in an acceleration of 6.92 m/s². The calculation for the coefficient of kinetic friction (u_k) yielded a value greater than 1, which raised concerns about its validity. It was clarified that while coefficients of friction are typically less than 1, values above 1 can occur in certain materials, indicating that the force required to move the object exceeds the normal force. The calculations for normal force (F_n) and frictional force (F_k) were also discussed, emphasizing the importance of accurate computations. This discussion highlights the nuances of friction coefficients in physics problems.
madelines
A 4.40 kg block is pushed along the ceiling with an constant applied force of F = 84.0 N that acts at an angle θ = 50° with the horizontal. The block accelerates to the right at 6.92 m/s2. Determine the coefficient of kinetic friction between the block and the ceiling.
u_k=(F_k)/(F_n)
ƩF=m*a
(pythagorean theorem for F_n)
I've tried this problem multiple different ways, but I keep getting a number that is greater than 1. Thank you!
F_n=(4.4*9.8)-(84*sin50)=-21.227733
-F_k=(4.4*6.92)-(84*cos50)=-23.546259
u_k=1.1092
but 0<u_k<1
I haven't checked your working but..
http://en.wikipedia.org/wiki/Friction#Coefficient_of_friction
Occasionally it is maintained that µ is always < 1, but this is not true. While in most relevant applications µ < 1, a value above 1 merely implies that the force required to slide an object along the surface is greater than the normal force of the surface on the object. For example, silicone rubber or acrylic rubber-coated surfaces have a coefficient of friction that can be substantially larger than 1.
Thank you! That cleared up some of the confusion!
  • · Replies 23 ·
  • · Replies 24 ·
