A block coming down the incline
In summary, the conversation discusses finding the work done by an applied force on a block. The equation for external work is used, but it is not consistent with the equation for work done by a force. The acceleration of the block is calculated assuming only the applied force and gravity are present, and the result differs from the given value. The concept of friction is brought up, but the important thing is to not make unjustified assumptions. The simplest and most direct method should be used to solve the problem. Overall, the work done by the given applied force is 100J.
rudransh verma
96
A block of mass 2kg is pushed down an inclined plane of inclination 37 degree with a force of 20N acting parallel to the incline. It is found that the block moves on the incline with a acceleration of 10 m/s2. If the block started from rest, find the work by the applied force in first sec.
##v=u+at##
##v^2=u^2+2as##
##W_{ext}=\Delta E##
##W_{ext}=mgh+KE_f+0=-20(5\sin 37)+(1/2)2(10^2)##
##W_{ext}=-60.18+100=39.81J##
But it’s not consistent with ##W=F.d=20*5=100J##
I can’t figure it out.
You are asked to find the work done by the applied force. (There are other forces that contribute to the net work done, but who cares?)
Likes Steve4Physics
That will be the total energy gained or lost by the block. During going down if it has gained some energy then it has also lost.
Nope.
Doc Al said:
Nope.
But I have used the eqn. ##W_{ext}=\Delta E##. It is asking for external work.
From your problem statement:
Is applied force not an external force?
Both ways should produce the same result W=100J
But is it the only external force? If it was, what would the acceleration be?
Yes, there is no non conservative force(friction) but there is a conservative force(gravity). I simply used the eqn ##W_{nc}+W_c+W_{ext}=\Delta KE##
I know what you did. You are assuming things without justification.
Now do what I ask: Calculate the acceleration of the block assuming that the only forces are the applied force and gravity.
a=16.01 m/s2 but it’s given 10. Is there friction?
Perhaps, but who cares? The important thing is to not make unjustified assumptions.
You need to learn to solve these sorts of problems in the simplest and most direct manner possible.
I thought friction was in the third part of the question(there are three parts). Maybe the author just thought that why not pour some friction in it at the end🤨
So we can’t use that eqn. We need to apply the definition of work. And then use this formula to calculate ##W_{nc}##.
That's all you need. You are given the force. You are given the acceleration.
Don't overcomplicate such an easy problem.
I try to.
So what’s going on is that the gravity is trying to increase the KE of the body while the friction is taking out. Net work is done by the applied force of 100J
Most likely. But you don't need to know what other forces act to answer the question.
Don't say "net work". Just say: The work done by the given applied force is 100J.
:bow:
