A homework assignment including rotation of a rigid body
The discussion revolves around a physics homework problem involving a car decelerating from 30 km/h to a stop over 2 seconds, with a wheel radius of 30 cm. Key calculations include determining the angular acceleration, total angle described by the wheel, number of turns made, and the stopping distance. Participants suggest converting linear speed to rotational velocity and using the given equations to find angular acceleration. The initial poster expresses difficulty in applying the equations but is encouraged to simplify their approach. The conversation emphasizes understanding the relationship between linear and rotational motion for solving the problem effectively.
stipan_relix
The problem is this: A car is evenly slowing down from 30 km/h to 0 in the time of 2 seconds. Radius of its wheels is 30 cm. What is its angular acceleration and what total angle will the wheel describe until it stops? How many turns does the wheel make and what is the length of the path the car travels while stopping?
\alpha = \frac{\Delta \omega}{\Delta t}\omega = \frac{\phi}{t}\phi= \frac{\alpha}{2}t^2s = vt
I honestly tried to use moment of inertia and tangential force equations and I just can't figure it out, every time I find a matching equation, something is missing and I can't solve it. Please help me, at least by some tips if you don't want to do the whole problem. Thanks.
You are over-thinking this. Think about how you can change the linear speed into a rotational velocity of the wheel. Hint: Today is appropriately 3/14/15, using the us convention for the date! From the initial angular velocity and the time to stop, you can calculate alpha, and on you go.
Thank you, I'll try it and report back!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
