A motor takes Ts to cover the distance ?
  • Thread starter Thread starter manal950
    Motor
To solve the problem of a motor covering a distance, the relevant kinematic formula is S = ut + 1/2at², where S is the distance, u is the initial velocity, a is the acceleration, and t is the time. This equation allows for the calculation of distance under uniform acceleration. By rearranging the formula, two equations can be derived to solve for acceleration and initial velocity. Understanding these equations is crucial for determining the motor's performance over time. Utilizing these kinematic principles will effectively address the question posed.
manal950
Hi
what is the idea for solving this question ?
http://store2.up-00.com/May12/28k31950.jpg
What kinematic formula might be relevant?
The equations of motion under uniform acceleration. You'll get two equations in 'a' and 'initial velocity', from which you can solve for the other variables.
Ok
then we use this equation
S = ut + 1/2at^2
thanks
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 29 ·
