A rational design for a personnel airlock
  • Thread starter Thread starter Noisy Rhysling
    Design Rational
The discussion centers on the inefficiencies of airlocks depicted in "The Martian," particularly their size and air wastage during use. A proposed solution is the "Suitport," a clamshell airlock design that minimizes space between the suit and the lock, allowing for more efficient air reclamation. The idea includes having multiple Suitports for quick egress, though concerns are raised about the increased risk of catastrophic failures due to multiple openings to the outside. The conversation critiques the large airlocks on the Hermes and Hab, suggesting that while they are suitable for freight, they are not ideal for individual use. The integration of smaller clamshell locks into existing airlocks could reduce air loss and structural stress, especially during urgent repairs, highlighting the need for more efficient airlock designs in space missions.
Noisy Rhysling
In The Martian we see airlocks that an SUV would fit into. Wastes air every time it's opened, even if pumped down.
I suggest we make an airlock that clamshells down on a space suit and leaves the minimum amount of room between suit and lock for air to be reclaimed from. You could have banks of these is you needed to get a lot of people out quickly. And you could have all kinds of drama around this system, priorities, etc., of use, especially if you just had one.
This concept is called Suitport.
You can avoid wasting air by pumping the air out, but that needs large pumps.
Worse than the huge airlocks is the "repair" that occurs later in the movie...
Likes ProfuselyQuarky
In my humble opinion, banks of these is not a viable solution.
Essentially, this would be a lot of openings to the outside, imho just more chances for catastrophic failures ala decompression because of xyz etc etc
So put the armor behind the airlocks. Troop marches into a bay, doors close, the troops cycle through the airlocks. You could have the armor be the deck. Lower it, the personnel move onto it, it returns to position and the troops cycle out through the clamshell locks.
I agree that no solution is perfect, but airlocks like we see on Hermes are good for freight, not egress by individuals. The airlocks on the Hab are hugely wasteful in space, but the clamshell individual locks could be built into the sides of those airlocks and there would be less air to be pumped out before a crewman needed to get out to work on urgent repairs, etc. Cycling large volumes of air in and out would stress the structure, as Mr. Watney demonstrated.
Recently, I’ve heard from Anton Petrov on YouTube that some tidally-locked planets around red-dwarf stars (such as TRAPPIST-1) have been suspected to flip around their own axis every once in a while — so that the former day side becomes the night side, and vice versa. This is presumed to happen for the same reason as why a T handle set in a rotating motion on a space station starts flipping back and forth. The latter is an issue we discussed for spaceship designs, when it came to how...
  • · Replies 39 ·
15K
  • · Replies 23 ·
  • · Replies 35 ·
