A rider cornering at maximum g
  • I
  • Thread starter Erunanethiel
  • Tags
    Maximum
In summary, the conversation discusses the use of the knee to bring a bike back to a vertical position while cornering at maximum lateral acceleration. It is mentioned that this technique is not effective and can cause the rider to wipe out due to decreased normal force on the tire. The conversation also mentions that it is not reasonable to try and use the knee for leverage or vertical travel while cornering. It is further explained that the bike is constantly countersteering while at the limit of cornering, and that the use of the knee to straighten the bike is insignificant. Finally, the conversation touches on the difference in load distribution between the front and rear tires while in a corner.
Erunanethiel
The rider is cornering at maximum available lateral acceleration so he is not able to countersteer to the "inside" in order to bring the bike to the vertical position. So he decides to push down to the road with his knee to bring the bike up, does that unload the tires by countering gravity and cause him to lose grip just as he would if he countersteered? Or wouldn't it be a problem since combined vectors of centrifugal force and gravitational force are in line with the motorcycle and pushing with your knee to the ground doesn't cause a problem?
I can tell you from personal experience with a recumbent bicycle that merely touching the inside foot down will unload the rear wheel enough to cause an instant wipeout. This particular recumbent would then end up sliding along with me perched on top. No scrapes (on me), no bruises. I did this several times before learning to keep my feet on the pedals and countersteer when it started to lose traction.
Likes Erunanethiel
This is a bad idea, since any force applied by the knee will decrease the normal force at the tire, causing it to be unable to support the lateral cornering loads. This causes the tire to slide, and as JRMichler said, it will cause the rider to wipe out.
Likes Erunanethiel
Have you tried doing anything with your knee during cornering at the racetrack, other than feeling your lean angle? It's not very reasonable to try to get any leverage or vertical travel with it to push yourself back up, IMO.
Unless you get in trouble, you will not be changing your lean angle mid-corner at maximum lateral acceleration and traction. You only start to straighten up after the apex as you open up your turn radius and power out of the turn, so you have the flexibility to use an outside bar push (countersteering) or outside peg weighting (body steering) or both at that time.
Likes Erunanethiel
ADD -- Not withstanding Marc's antics in MotoGP saving slides...
ADD2 -- Valentino Rossi used to relax his legs like that going into turns too. I guess it's getting more common now...
Likes Erunanethiel
A bike, by design, "wants" to go straight. When cornering at the limit, you are constantly countersteering (push inside bar, pull outside), simply eliminating your countersteering will pick the bike back up.
You are already sliding at maximum cornering, pushing the outside bar and/or pulling the inside bar the amount needed to pick up from a corner is insignificant.
In a corner, taken properly, the front will have a bit more work to do until just before the apex, after that, the rear has a much higher load on it. (Hence the larger size)
FAQ: A rider cornering at maximum g
1. What does it mean to "corner at maximum g"?
Cornering at maximum g refers to the maximum amount of lateral acceleration that a rider can achieve while navigating a turn on their motorcycle. This is the point at which the forces acting on the rider and bike are balanced, allowing for the sharpest turn possible without losing control.
2. How is maximum g achieved while cornering?
Maximum g can be achieved by maintaining the correct speed and body position while entering and exiting the turn, and smoothly rolling on and off the throttle. It also requires a skilled use of the brakes and a smooth line through the turn to minimize any disruptions to the balance of forces.
3. What is the importance of cornering at maximum g?
Cornering at maximum g is important for both performance and safety. It allows for quicker turns and faster lap times on the track, while also ensuring that the rider maintains control and stability on the road. It also puts less strain on the tires and improves overall handling of the motorcycle.
4. Can all riders corner at maximum g?
No, not all riders are able to corner at maximum g. It requires a combination of skill, experience, and confidence to achieve and maintain this level of performance. Riders must also have a well-maintained motorcycle and appropriate gear to handle the forces involved in cornering at maximum g.
5. What are some common mistakes that prevent riders from cornering at maximum g?
Some common mistakes that can prevent riders from cornering at maximum g include braking too hard or too late, poor body positioning, and not maintaining a smooth line through the turn. Inexperienced riders may also struggle with throttle control and maintaining proper speed. It is important to practice and develop good technique to overcome these challenges and achieve maximum g.
