About work done through exercise (push ups)
The discussion revolves around the physics of work done during push-ups, specifically calculating the energy expenditure of a 50kg woman performing the exercise. The initial calculation estimates that approximately 3 push-ups would expend 300J of energy, with each push-up requiring about 98J of work. Participants highlight the complexity of biomechanics, noting that while the work done in lifting and lowering the body can cancel out to zero, significant energy is still expended by muscles, leading to fatigue. The conversation emphasizes that energy is dissipated as heat rather than stored, complicating the understanding of work in human movement. Overall, the exercise illustrates the inefficiency of the human body in converting energy during physical activity.
Iwanttolearnphysics
A 50kg woman does push-ups by applying a force to elevate her center of mass by 0.2m. Estimate the number of push ups that the woman must do in order to expend 300J of energy.
W = Fs
Hello, everyone. I'm not sure if I did this problem right because there's no answer key. I got this question from a high school introductory Physics book. But it's jaded and I accidentally poured coffee on it, so I can't take a picture of the question. I copied it word for word though.
This is what I did, please let me know if I did anything wrong.
  • W = mas
  • W = 50(-9.8)(0.2)
  • W = 98 J
  • 300 J/98 J =3.06
  • So I think it will take approximately 3 push ups for her to use up 500J of energy.
  • I'm unsure if this is correct. What happens as the distance between her and the ground decreases? Does she do positive work while moving towards the ground? Does she do negative work while being lifted by her arms?
  • According to wikipedia, work is the energy transferred to or from an object via the application of force along a displacement. In its simplest form, it is often represented as the product of force and displacement.
  • Energy is a scalar quantity, but there is such a thing as negative work, right?
  • If the work done while she's pushing up on the ground is negative, and the work done as she's coming back to the ground is positive, won't that mean that ultimately she didn't get any work done because they'll cancel out?
Iwanttolearnphysics said:
Homework Statement:: A 50kg woman does push-ups by applying a force to elevate her center of mass by 0.2m. Estimate the number of push ups that the woman must do in order to expend 300J of energy.
Relevant Equations:: W = Fs
This is a poor question, because biomechanics is generally more complicated than elementary physics, owing to the way the muscles work. The woman would get tired simply remaining in the "plank" position at the top of a press-up, without moving at all.
The question would do better to ask you to analyse the work done on an object as you raise and lower it. The human body is generally very inefficient, so the external work done is often much less than the energy expended (I'm not even sure that's a well-defined term, but let's assume it's how much energy is produced by her muscles).
  • W = mas
  • W = 50(-9.8)(0.2)
  • W = 98 J
  • 300 J/98 J =3.06
That's the elementary calculation all right. To do a press-up requires the woman to do about ##98J## work on her own body mass.
  • What happens as the distance between her and the ground decreases? Does she do positive work while moving towards the ground? Does she do negative work while being lifted by her arms?
On the way down, or when you lower an object, you must do negative work on the object. In other words, your muscles must absorb the energy in some way. This energy doesn't get stored like in a spring, but rather gets dissipated as heat in your muscles. Again, biomechanics is quite complicated.
Energy is a scalar quantity, but work is a scalar product (of two vectors), which can be negative or positive.
The work done overall by a press-up and down is, indeed, zero. In an idealised scenario, the energy would start stored as chemical energy in your muscles and end as heat in your muscles. That's approximately the effect of doing press-ups!
This is why your muscles tire, even though you are doing zero work overall: you are expended the chemical energy in your muscles which must eventually be replaced.
Likes Iwanttolearnphysics and Lnewqban
If her center of mass is free falling those 0.2 m, she doesn't have to do any muscular effort, until she has to stop the downwards movement.
Normal push ups are done slower than that, and there is energy used to slowdown that downwards movement.
The question would do better to ask you to analyse the work done on an object as you raise and lower it. The human body is generally very inefficient, so the external work done is often much less than the energy expended (I'm not even sure that's a well-defined term, but let's assume it's how much energy is produced by her muscles).That's the elementary calculation all right. To do a press-up requires the woman to do about ##98J## work on her own body mass.
On the way down, or when you lower an object, you must do negative work on the object. In other words, your muscles must absorb the energy in some way. This energy doesn't get stored like in a spring, but rather gets dissipated as heat in your muscles. Again, biomechanics is quite complicated.Energy is a scalar quantity, but work is a scalar product (of two vectors), which can be negative or positive.
Thank you. Yeah, I figured that it would be more complicated than that, and I had to stop using that book anyway because I feel like it's too dated. Appreciate the detailed response. I'd give you a hundred thumbs up if I could!
Thank you! Appreciate the response.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
