Acceleration of system, connected to a rotational body
The discussion revolves around calculating the acceleration of a system involving a disk, a cylinder, and a falling mass connected via a pulley. The user seeks to understand how a smart timer measured an acceleration of 0.4 cm/s² and requests the raw formulas behind this calculation. Responses emphasize the need to consider the moment of inertia of the rotating components and the effective rotational inertia of the falling mass. Additionally, the impact of frictional torque from the bearings must be accounted for in the calculations. The conversation highlights the importance of both experimental data and theoretical analysis in understanding the system's dynamics.
jason lee
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >[/color]
I have a problem here.
what's the formula for the acceleration of a system wherein.
A disk with a cylinder on top of it with a shaft underneath to wound the thread to connect it with a pulley with a falling mass.
I already got the free body diagram of the falling mass. I have a problem in knowing the diagram for the left side.
we did this in the lab, which the smart timer for acceleration calculated it.
I want to know how did the smart timer get that acceleration through raw formulas. Thanks everyone! :D
Let's say these are the given
M(disk) = 1415.4g
M(ring) = 1428.2g
R(disk) = 11.6cm
R1(ring) = 5.4cm
R2(ring) = 6.4cm
g = 980 cm/s^2
r(shaft) =1.2cm
m = 55g
The smart timer read the acceleration to be 0.4 cm/s^2
i need to get the raw formula for this reading thanks!
What exactly is a 'smart timer'? I would have guessed it was physically measuring the movement and calculating the acceleration from that. Its 'formulas' would be based on samples of time and either speed or position.
But from the rest of your post I would have thought that what you wanted was a theoretical calculation of the acceleration based on the set-up. If so, please post an attempt at a solution.
You need to consider the (rotational) moi (moment of inertia) of all the rotating parts, and also express the falling mass also in terms of its effective rotational moi
The force driving the system, you get from the hanging mass.
Don't forget the frictional torque from the bearings.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
