After 14ms the current drops -- Find the capacitance at C
The discussion focuses on analyzing an RC circuit to find the capacitance and total current after a specified time. Participants suggest simplifying the circuit by combining resistors and capacitors to better understand the behavior when the switch is closed. The total resistance is calculated as 4kOhm, and the capacitors in parallel are represented as (3+C) microFarads. To determine current over time, participants recommend using the general formulas for charge or voltage in RC circuits. The conversation emphasizes the importance of consulting class notes or external resources for detailed formulas related to RC circuit discharge.
Kelsi_Jade
Here is what I have so far. Am I going the right direction?
If so, how do I go about finding the total current?
See photo above.
See above.[/B]
Is that what you are asked?
You are given two values for the current at different times. You'll want to use them at some point...
What kind of circuit is this? If you simplified the circuit, combining the capacitors and combining the resistors, what are you left with? What kind of behavior would you expect when the switch closed? What's the general formula for the current with respect to time for such a circuit?
Well, since the resistors are in series you can combine them to equal one resistor with a resistance of 3+1= 4kOhm.
The capacitors in parallel would equate to one capacitor with 3+C= (3+C)microFerrads.
Current with respect to time would be = Q/Δt ?
Yes, so you have a basic RC circuit (resistor - capacitor circuit).
Your class notes or textbook should show a general formula for the charge or voltage or current with respect to time for such a circuit. If not, do a web search on "RC circuit discharge". Here's an example hit:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capdis.html
