Astock
- 8
Hi PF! Though I've lurked here for some time, this is the first time I've created an account.
I'm a volunteer in a country in West Africa. The school I teach at has a tiny library with 4 small dell PC's and a printer that were donated some time ago. A grant was used years ago to buy a battery and solar panel, but after a while the battery died and I've found that they're not economical on such a miniscule budget. I stumbled across a "scrap-metal battery" (https://news.vanderbilt.edu/2016/11/02/making-high-performance-batteries-from-junkyard-scraps/) and found the paper (not available without $.. but I have my ways...). I have found most of the supplies in a larger city near my village, and believe it to be feasible. Maybe I'll make another post about that.
Now for the actual problem... IF it does work, the voltage will be at most 1.something. The power regulator, solar panel, etc etc are all set up to work with a 12v battery.
A) Buying and shipping a commercial amplifier (I'd need two, really..one to drop the solar panel voltage, and one to raise the battery voltage) would be expensive and defeat the point of giving the school an economic solution.
B) I could put several cells in series, but this complicates the battery construction... I'd have to build maybe ~8 identical cells, test and tweak so they have the same capacity (tricky) and assume the cells all age at the same rate. Otherwise, the weaker ones will be damaged after they discharge first.
C) I could pry opamps out of trashed electronics, maybe? And find resistors (maybe?) to make voltage amplifiers. But I have doubts about their efficiency. My education is in Computer Engineering so it'd be awesome to take this route but I have doubts about it's practicality as well.
Option (A) seems to be the cleanest and I might be able to find grant money (sorta defeating the purpose of the project, but if the claims of the researchers hold, they'd at least have a battery that works for 5,000 cycles). If I take option A, what kind of commercial product can I use? Everything I find online is for RF/AC, not DC, applications. Maybe someone could point me in the right direction.
What have I not thought of yet? What do you think, PH?
