Amplitude and Young double slit experiment
In the context of the Young double slit experiment, reducing the size of one slit does not decrease the amplitude of light but rather affects the power or intensity of the light passing through that slit. The amplitude of light is typically linked to its intensity, which remains uniform across the slit when illuminated by a plane wave. Therefore, while the overall power decreases with a smaller slit, the amplitude itself does not change. This distinction is crucial for understanding the behavior of light in the experiment. The discussion emphasizes the importance of differentiating between amplitude and power in wave physics.
MBBphys
For a question in a worksheet (the actual question is irrelevant), my physics teacher said, in the context of the Young double slit experiment with light, if you make one of the slits smaller, then the amplitude of light from that source will also decrease.
Is that true?
N/A
N/A
How did your teacher define light amplitude?
As far as I know, the amplitude of light is most often associated with the intensity. If the two slits is illuminated by a plane wave, the intensity and hence the amplitude across the slit opening is uniform. Reducing the slit size will obviously not affect the intensity, instead, it's the power (energy/time) which is decreasing.
