Amplitude of harmonic oscillation given position and velocity
The discussion revolves around finding the amplitude of harmonic oscillation given initial position and velocity. The key formula derived is a = √(x₀² + (v₀/ω)²), which relates amplitude to initial conditions. Participants suggest using trigonometric identities and standard equations of motion to simplify the derivation. There's also mention of using the phase factor to derive the equations, although a more straightforward approach is recommended. Ultimately, the conversation emphasizes understanding the relationships between displacement, velocity, and amplitude in simple harmonic motion.
zenterix
A particle performs harmonic oscillations along the ##x##-axis about the equilibrium position ##x=0##. The oscillation frequency is ##\omega=4\text{s}^{-1}##.
At a certain moment of time the particle has a coordinate ##x_0=25\text{cm}## and its velocity is equal to ##v_{x0}=100\text{cm/s}##.
Find the coordinate ##x## and the velocity ##v_x## of the particle ##t=2.40\text{s}## after that moment.
##x(t)=a\cos{(\omega t-\phi)}##
##v(t)=-a\omega\sin{(\omega t-\phi)}##
##x(0)=a\cos{(-\phi)}=x_0##
##v(0)=-a\omega\sin{(-\phi)}=v_0##
##\implies \tan{(-\phi)}=-\frac{v_0}{\omega x_0}##
##\implies \phi=-\tan{\left (-\frac{v_0}{\omega x_0}\right )}##
The solution to this problem says that we can find ##a=\sqrt{x_0^2+(v_{x0}/\omega)^2}##
How do we find this expression?
For the given values of ##\omega, x_0##, and ##v_{x0}## we have ##\phi=-\frac{\pi}{4}## and so we can find that
##x(0)=a\frac{\sqrt{2}}{2}=x_0##
##a=\frac{2x_0}{\sqrt{2}}##
The answer seems to be that we multiply the equation for ##x(0)## by ##\omega##, square it, add it to the square of the ##v(0)## equation, and solve for ##a##.
I wonder if there is a simpler way that comes about through intuition about the meaning of the equations. At least for me this was just an algebraic trick.
From your expression for ##x(0)##, $$a^2=\frac {x_0^2} {cos^2(-\phi)}$$
From trig, $$cos^2(\alpha)=\frac 1 {1+tan^2(\alpha)}$$
Then, algebra...
It’s conventional to use upper case ##A## for amplitude. (Lower case ##a## is acceleration.) So another way to get the above formula is:
##x(t) = A \cos(\omega t - \phi)##
##v(t) = -A\omega \sin(\omega t - \phi)##
Use ##\cos^2 + \sin^2 = 1## and this will give the formula relating ##A, \omega, x## and ##v##.
If you’re allowed to use it directly, there is a handy 'standard' SHM formula for velocity as a function of displacement: ##v = \pm \omega \sqrt{A^2 -x^2}##. This can easily be rearranged to give the formula for ##A##.
Likes SammyS and PeroK
If I was looking at this problem for the first time, I would do this.
Take ##t = 0## when the object is at the origin. Then, the equation of motion is:
$$x = A\sin(\omega t)$$That must be easier than messing about with a phase factor. Then, of course:$$v = \omega A\cos(\omega t)$$You are given ##\omega## and ##x_0, v_0## at some unknown time ##t_0##. That's two equations in two unknowns. Solve for ##t_0## and ##A##, then plug in ##t_0 + 2.4s##.
Even if that's not the neatest or quickest way, it's the sort of thing you should be able to do by now.
PS as a byproduct, you get the expression for ##A## when you eliminate ##t_0##.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
