A Analemma layout and proportions on a sundial
  • A
  • Thread starter Thread starter 1940LaSalle
The discussion focuses on laying out an analemmatic sundial using a true figure 8 analemma for gnomon positioning. Key points include the understanding that the ordinates of the analemma curve relate to the sun's declination, while the abscissae correspond to the equation of time. The user seeks clarity on the proportions between the equation of time and the sun's declination. A suggestion is made to convert the equation of time from minutes to degrees to ensure consistent units for plotting. This conversion is essential for accurately determining the relationship between the two axes in the sundial's layout.
1940LaSalle
TL;DR Summary
Looking for proportions and similar guidance in laying out an analemma: specifically, the abscissa (equation of time) component. Sun declination is fairly easy to get.
I want to lay out an analemmatic sundial, with a true figure 8 analemma for the gnomon position instead of the more common date marks. Everything I read shows that the ordinates of the points on the curve are a function of the sun's declination on a given date. Further, I'm also given to understand that the abscissae are functions of the equation of time on a given date--and the equation of time is fairly easy to get from a source like Meeus' Astronomical Algorithms. What has me baffled is the proportions of the analemma.
I recall that the height of the analemma is some fraction of the major axis of the ellipse on which the hour points are laid out. Let's call that D, since it comes from the sun's declination. I believe that the equation of time varies from about -15 minutes (sun lags behind clock time) to +15 minutes (sun precedes clock time) over the course of a year. Let's call the range of abscissae that cover that ±15 minutes E, for equation of time. What I haven't found and need is the proportion of E to D--or if not a set proportion, a range of values. And a reference for this information would be extremely valuable.
Thanks very much.
Astronomy news on Phys.org
I think your problem is that you have one axis (D) in degrees, and the other axis (E) in minutes. You need to convert E into degrees so you can plot them both in the same units. Since the sun moves 360 degrees in 24*60 = 1440 minutes, E of 15 minutes is an angular deviation E = 15 * 360 / 1440 = 3.75 degrees. Does this help? This link might be useful.
Likes sophiecentaur
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
13K
25K
14K
