I Angles between 4-vectors in special relativity?
LightPhoton
TL;DR Summary
How do we define angles in relativity? do we change the usual euclidean definition or extend it?
How is the angle between two 4-vectors defined in special relativity? Consider two 4-velocity vectors:
$$U^\mu=(1,0), \\ V^\mu=\gamma_{rel}(1,v_{rel})$$
Where the vectors are written in the frame of the particle with ##U^\mu##.
The dot product between these is
$$U^\mu V_\mu=\gamma_{rel}$$
If we define angle ##\theta## between two vectors as:
$$\cos\theta=\frac{U^\mu V_\mu}{\vert U\vert\vert V\vert}$$
then since all velocity vectors have magnitude of ##1##, we get ##\cos\theta= \gamma_{rel}\geq 1##.
But what does this mean?
LightPhoton said:
TL;DR Summary: How do we define angles in relativity? do we change the usual euclidean definition or extend it?
It means Minkowski spacetime is manifestly non-Euclidean.
Likes Hornbein and Ibix
If both ##U## and ##V## are unit and timelike then their inner product is ##\cosh\psi##, where ##\psi## is the rapidity. Rapidity has a one-to-one relationship with speed, and is additive (at least in one dimension). But it's not much used except to reframe the Lorentz transforms as manifestly the Minkowski analogue to Euclidean rotations.
If both ##U## and ##V## are unit and spacelike then their inner product is the Euclidean inner product.
If the vectors are different types the inner product remains useful, but I'm not sure it has a meaningful interpretation in terms of angle-type quantities.
Likes Dale and PeterDonis
Hornbein said:
I always liked rapidity a.k.a. celerity.
Rapidity and celerity are different things. Rapidity is ##\psi## and ##v=c\tanh\psi##, but celerity is ##dx/d\tau=\gamma v##
I think rapidity is one of those things that isn't particularly useful once you go on to GR, so it's an interesting but fairly niche concept. Celerity is best forgotten about, IMO.
velocity = c tanh (rapidity)
celerity = c sinh (rapidity)
time-dilation-factor = cosh (rapidity)
Doppler-factor = exp (rapidity)
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
