AP physics 2: Phase change in thin film interference
  • Thread starter Thread starter AAONA
When light reflects off a boundary from a medium of lower refractive index to a higher one, a 180° phase change occurs. In this scenario, light travels from air to the first layer (n₁ = 1.404) and then reflects off the glass (n_glass = 1.62). The reflection at the glass interface results in a 180° phase change, while the transition from air to the first layer does not induce a phase change. Therefore, the total phase change for light reflecting from the glass is 180°. The confusion arises from not accounting for the direction of light travel and the phase changes at each interface correctly.
AAONA
2t=. 5m/wavelength
180° phase change if n2>n1
47. Two thin layers of material with different indices of refraction are coated on a glass plate. The outer first material has n₁ = 1.404, the inner second material has n₂ = 1.531, and the glass has glass = 1.62. If light is incident from air on the first layer, what is the phase change for light that reflects from the glass?
a. 0°
b. 180°
c. 360°
d. 540°
Apparently the answer is 180, but I don't get it. I assumed since it's low n» high» higher > two consecutive 180° phase changes since moving to a denser meduim produces a 180° phase change, so 360° which is equivalent to zero.
What am I missing?
The questions asks about the light reflected from the glass, so must traverse the layers in the opposite direction as well.
Likes AAONA, SammyS and berkeman
