Are PEDs Impacting Amateur Sports Integrity?
  • Thread starter Thread starter thepioneerm
thepioneerm
Please:
I had a look at it and after a few minutes I got a transformed result, but indeed it is not the one given. However there seems to be a term missing in the left hand side containing the time t. After using the transformation I got (without the term with the time):
u^*\frac{\partial u^*}{\partial x^*}+ v^*\frac{\partial u^*}{\partial y^*}= m\cdot \frac{U^{n-1}}{L^n}\cdot \left[M\cdot \theta + \frac{\partial}{\partial y^*} \left[\left|\frac{\partial u^*}{\partial y^*}\right| ^{n-1} \right]\cdot \frac{\partial u^*}{\partial y^*}\right]
Maybe the term with t can shed some light on the necessary next step, otherwise I do not see how to reach the end result.
coomast
coomast
thank you very much
but how do you reach this result ??!
please can you explain it to me
even I don't know how to get
thepioneerm said:
coomast
thank you very much
pfff...the preview gives a different formula then the one I'm typing, I assume the latex is still broken
This is done in the same way as before, you have:
v\frac{\partial u}{\partial y}=v^*U\frac{\partial u^*U}{\partial y^*L} = \frac{U^2}{L} v^*\frac{\partial u^*}{\partial y^*}
After doing this to the other terms as well, you end up with the result I gave earlier. Beware of the error in the question, you will not be able to reach the solution given.
remark 1: sorry for the late reply, I had a busy week
remark 2: don't use a font this big, it looks as if you are shouting which is not the intention I suppose, instead look at learning the basics of latex, it will be helpfull in producing the nice formula's out here :-) [if the bloody thing works, lol]
seems the latex is OK after all... this does not follow a mathematical rule, perhaps something chaotic...could be me as well...
best regards,
coomast
coomast
thank thank thank you very very very much
and I will not use a font this big ^-^
and I will try to learn the basics of latex
thank you
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
