Assistance needed with vector velocity problem, please
An asteroid heading toward Earth at 15 km/s was modified with a rocket engine, increasing its speed to 19 km/s at an angle of 28° after 10 minutes. The average acceleration needs to be calculated using the change in velocity components. The initial approach used the cosine formula to find the magnitude of acceleration but did not address direction. The discussion suggests using a coordinate method to determine the acceleration components (ax, ay) more efficiently. The participant ultimately understood the correct method after some guidance and reflection.
SelHype
An asteroid is discovered heading straight toward Earth at 15 km/s. An international team manages to attach a giant rocket engine to the asteroid. The rocket fires for 10 min, after which the asteroid is moving at 28\circ to its original path at a speed of 19 km/s.
Find its average acceleration (ax, ay) in m/s2.
I first began by using the equation a2 = b2 + c2 -2bc(cos\alpha) where b is 15 km/s and c is 19 km/s.
a2 = 225 + 361 - 570(cos28\circ)
a2 = 82.7 km/s
9.1 km/s m= \Deltav
a= 9.1 / 600 = .0152 km/s2 = 15.2 m/s2 The answer is r\hat{} = (3.0i\hat{} + 15 j\hat{}) m/s2.
I am unsure as to whether or not I have done this correctly because I do not know where to go from here. My professor gave use this hint for this problem:
The asteroid is initially going in the +x direction! From the given initial and final
velocities, find \Deltavx and \Delta vy. Use ax = \Deltavx/\Deltat and ay = \Deltavy/\Deltat
Welcome to PF!
a2 = 82.7 km/s
9.1 km/s m= \Deltav
Hi SelHype! Welcome to PF! :smile:
The question asks for (ax, ay).
Your cosine formula only gave you the magnitude, |a| (which was correct :wink:) …
but you won't get the direction without using the sine formula also, which is far too long-winded a method.
There are two ways of dealing with vectors … the good old trigonometry way that the ancient Greeks would have used, and the coordinate method.​
You've used the slow ancient Greek way.
Your professor wants you to use the quicker coordinate way. :wink:
Do what your professor suggested … :smile:
Thank you for the welcome!
I should have known I was doing it the long way, haha. I am VERY bad for going the more complicated routes because...well they seem easier...Yeah I'm odd.
But thank you for the help! I finally got it after I looked at it for bout another hour, haha.
Anyways, thanks again!
