Average acceleration of an arrow by a bow
The discussion centers on calculating the average acceleration of an arrow shot from a bow, using the equation Distance = (Initial Velocity + Final Velocity / 2) Time. The initial calculations suggest an average acceleration of 3750 m/s², assuming constant acceleration. However, it is noted that the force exerted by the bowstring decreases as it relaxes, leading to non-constant acceleration, which makes the initial equation potentially invalid. Some participants suggest that the problem may be simplified for educational purposes, allowing for the assumption of constant acceleration. Overall, while the calculations appear correct under certain assumptions, the complexities of real-world physics are acknowledged.
rxhim631
An arrow is accelerated for a distance of 75 cm [fwd] while it is on the bow. If the arrow leaves the bow at a velocity of 75 m/s [fwd], what is the average acceleration while on the bow?
Distance= (Intial Velocity + Final Velocity / 2) Time
Acceleration = (Final Velocity + Intial Velocity) / Time
0.75 = (0+75 / 2) Time
0.75 = (37.5) Time
0.02 seconds = Time
Acceleration = (75 - 0) / 0.02
Acceleration = 3750 m/s2
Idk if this is correct can someone help pls.
rxhim631 said:
Relevant Equations:: Distance= (Intial Velocity + Final Velocity / 2) Time
This equation is not true in general. It is valid for the case of constant acceleration along a line. A bow string will exert a force on the arrow that decreases in strength as the string relaxes. So, the arrow will have a non-constant acceleration while it is being pushed by the string. This means that the above equation is not actually valid. However, it could be that this is an exercise where they want you to treat the arrow as having a constant acceleration. Otherwise, I don't think there is enough information to work the problem.
Another somewhat picky point is that you need to include additional parentheses to conform to standard conventions for "order of operations":
Distance= ((Intial Velocity + Final Velocity) / 2) Time
Did you mean to type a minus sign instead of the plus sign?
Your calculation looks OK. I think your final answer is correct if we can assume that the acceleration is constant.
Likes Lnewqban and rsk
If we make the reasonable assumption that the motion is approximately SHM, the average acceleration is ##4/\pi## times as much.
