Ball revolving around a massive disc and a cube placed at centre
The discussion centers on the dynamics of a ball revolving around a massive disc with a cube at its center. The initial assumption is that the maximum force on the block occurs when the ball crosses the center plane, leading to maximum friction. However, this reasoning is flawed because the normal reaction force on the cube varies as the ball moves, affecting the limiting frictional force. A free-body diagram is suggested to clarify the forces acting on the cube at different positions of the ball. Additionally, it's noted that the ball can sometimes be below the disc's plane, complicating the analysis.
someone_2156
Consider a thought experiment performed in free space. In the experiment, a small cube C of mass m is placed at the center of a large and highly massive disc D and a ball B of mass M revolves in circular path of radius R around the center of the disc. The plane of the circle is perpendicular to the plane of the disc as shown in the figure. Intensity of the gravitational field of the disc near its center is g. What should be range of coefficient of friction between the cube and the disc so that the cube remains motionless?
##F=GmM/R^2##
I thought that the maximum force on the block in the x direction would be the point where the ball crosses the plane of center and thus frictional force would be maximum, and if the block does not slip in that case then it never will slip as the value of force in x direction only decreases. However this gives a wrong solution. What is wrong with my line of thought in this problem?
Note that the normal reaction of the disc on the cube will change as the ball moves in its orbit. So the limiting frictional force will also depend on the position of the ball.
A free-body diagram of the cube with the ball at some arbitrary position should help.
Edit: And don't forget that the ball is sometimes below the disc's plane.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
