B Black hole electromagnetic spectrum
snorkack
Of course neither a single Schwarzschild nor a single Kerr black hole, nor a pair of these has an emission spectrum, other than the Hawking one. (Nordström and Newman holes must have it while in binaries, but they are not common).
But not having emission spectrum does not rule out having absorption and deflection spectra. Nor of shift spectra.
For light of short wavelength compared to Schwarzschild radius, a single Schwarzschild black hole has simple, black spectrum dictated by geometry. GR can treat light as rays and geometrically derive the amount of light intercepted by event horizon, and deflected by any angle.
But what happens when the wavelength is appreciable compared to the Schwarzschild radius? A black ball would deflect such waves by diffraction. A black hole should have interplay of gravity and diffraction. So what does Schwarzschild black hole cross-section for absorption and deflection do for the parts of spectrum where the wavelength is comparable or bigger than Schwartzschild radius?
Now, I mentioned shift spectra.
A lone Schwarzschild black hole would not shift frequency in a reference frame where it is stationary. Waves would be absorbed or deflected but not change frequency. It would Doppler shift frequency of deflected waves in frames where it moves.
Binary black holes are moving in reference frame where their common centre of mass is stationary, so of course they Doppler shift deflected waves.
But how about Kerr black holes? Is there any frequency shift for electromagnetic waves that pass through ergosphere and get out again?
I'm not sure what you mean. An "absorption spectrum" would mean absorbing some wavelengths but not others. A black hole absorbs all wavelengths.
Where are you getting this from? Do you have a reference?
Again, where are you getting this from? Do you have a reference?
Likes Vanadium 50
Yes, but does the black hole absorb all wavelengths exactly equally?
Even wavelengths that are in the order of magnitude of black hole size?
Reference for what?
For the black hole deflection or absorption of light, a simple example is this:
https://www.spacetimetravel.org/expeditionsl/1
Many references duplicate this simple picture - pure ray geometry.
Which I reworded as "simple black spectrum" - absorption cross-section independent on wavelength.
For the wavelengths where this simple model holds.
What I do not find references for is what happens for wavelengths where this ray optics models necessarily breaks down. A black absorbing obstacle will create a diffraction and interference pattern. Therefore, for a black hole interrogated with a plane wave whose wavelength is appreciable compared to the black hole size, I should expect interplay of gravitational bending with diffraction and interference. Who discuss that?
Uh, this?
Basic relativity of light frequency?
If a mirror, in a reference frame where it is stationary leaves the light frequency unaltered then in a reference frame where the mirror moves towards or away from light it Doppler shifts the light - respectively blueshift and redshift.
Therefore, if a Schwartzschild black hole in a reference frame where it is stationary leaves the frequency of deflected light unaltered (it blueshifts when approaching the hole, but redshifts back to exactly the initial frequency when escaping to infinity), in a reference frame where it moves relative to the direction of light direction change it must Doppler shift the light frequency.
Any light that goes into the hole is absorbed.
That would depend on which theoretical model you use.
Observationally we can't detect such long wavelengths, so we have no way of checking our theoretical models in this regime.
snorkack said:
Reference for what?
For your claims about the spectrum of a black hole.
That's not a valid reference.
Then you should have no trouble finding a textbook or peer-reviewed paper.
Then you should not be making claims about what happens in that case.
snorkack said:
Uh, this?
Sorry, no. Either you have a valid reference to back up your claims, or you don't. Since you have said you don't, your claims are personal speculation, which is off limits here.
Thread closed.
As a side note, this has nothing whatever to do with the presence of a black hole; it would be the same in flat spacetime. So it has nothing to do with any claims you are making about black holes.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
