Undergrad Black Holes Colliding Exactly Head On
  • Thread starter Thread starter peanutaxis
When two black holes collide head-on, the gravitational potential energy is transformed into gravitational radiation, which carries energy away from the system. The collision results in a larger black hole, with the energy contributing to its mass and spin. The dynamics of the collision are complex and differ from those of black holes that spiral into each other. Understanding these interactions requires considering the unique spacetime characteristics created by the black holes. Overall, the energy from a head-on collision impacts the final black hole's properties significantly.
peanutaxis
TL;DR
Where would the energy go?
Hi,
So when black holes circle each other and eventually collide to form one larger black hole [I believe] that the gravitational potential energy is turned into ripples in spacetime. But that makes me wonder, what if two black holes collided exactly head on? Surely there is a massive amount of gravitational potential energy that.....where would it go?
Thanks,
p
It isn't as simple as "gravitational potential energy", since you can't really define that in the kind of spacetime you get with two black holes. However, energy is carried away as gravitational radiation, yes. If it doesn't get carried away somehow it simply contributes to the mass or spin of the final black hole. So two holes colliding head on make a different (probably larger) black hole than an identical pair that spiral in.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 20 ·
