Block pushed up frictionless incline
In summary, a block with a mass of 3 kg is pushed up a frictionless 30° incline by an applied force of 50 N. To find the resulting acceleration of the block, we can use Newton's 2nd law and solve for the force components parallel to the plane. Using this method, we get an acceleration of 11.77 m/s^2. It is also helpful to draw a free body diagram and use components parallel and perpendicular to the plane for easier problem solving.
mooneh
24
a block is pushed up a frictionless 30 incline by an applied force
the force F=50 N and the mass = 3 kg
whats the magnitude of the resulting acceleration of the block ?
sol:
-Fcos30=ma
mg+Fsin30=ma
right answer for a=9.4
These problems will be easier to solve if:
(1) You draw yourself a free body diagram
(2) You use components parallel (and perpendicular) to the plane
In this case, apply Newton's 2nd law to force components parallel to the plane (since that's the only direction that the object can move).
(Extra hint: If you insist on using vertical and horizontal components, you will need to add the normal force into the mix.)
Right answer is a=11.77m/s[tex]^{}2[/tex]
Because F-mgsin(30)=ma so 50-3*9.8*0.5=3a and a=11.77m/s[tex]^{}2[/tex]
FAQ: Block pushed up frictionless incline
How does the incline affect the block's movement?
The incline affects the block's movement by changing the direction of the force of gravity. The force of gravity acts downward towards the center of the earth, but when the incline is introduced, it acts perpendicular to the surface of the incline. This results in a component of the force of gravity that is parallel to the incline, causing the block to move.
Why is friction not a factor in this scenario?
Friction is not a factor in this scenario because it is assumed that the incline is frictionless. This means that there is no resistance to the block's movement along the incline, allowing it to move without any additional force acting against it.
How does the angle of the incline affect the block's acceleration?
The angle of the incline affects the block's acceleration by changing the magnitude of the component of the force of gravity acting parallel to the incline. As the angle of the incline increases, the component of the force of gravity acting parallel to the incline also increases, resulting in a greater acceleration of the block.
Does the mass of the block affect its movement on the incline?
Yes, the mass of the block does affect its movement on the incline. According to Newton's Second Law of Motion, force is equal to mass times acceleration. This means that a greater mass will require a greater force to accelerate it. Therefore, a heavier block will move slower than a lighter block on the incline.
How does the length of the incline affect the block's movement?
The length of the incline does not directly affect the block's movement, but it does affect the acceleration of the block. A longer incline will result in a smaller angle, and therefore a smaller component of the force of gravity acting parallel to the incline. This will result in a slower acceleration of the block compared to a shorter incline with a steeper angle.
