Bomb explosion -- calculating the momentum of one of the fragments
The discussion focuses on calculating the momentum of fragments from a bomb explosion, emphasizing that the total momentum must balance out regardless of the direction of the fragments. One participant initially expresses doubt about their approach but later acknowledges that the direction of movement does not affect the overall momentum balance. The importance of considering the resultant vector in opposite directions is highlighted. A request for verification of another post is made, indicating a desire for further clarification on related topics. The conversation ultimately reinforces the principle of momentum conservation in explosive events.
rudransh verma
A bomb at rest explodes into 3 parts of the same mass. The momentum of the 2parts is -2pi^ and pj^. The momentum magnitude of the third part will be
##\vec R=\sqrt{{a\hat i}^2+{b\hat j}^2}##
I think if the two parts move in -x and +y direction, it must be balanced by the resultant of the two vectors but in opposite direction.
So ##p\sqrt5## will be the answer.
But I don’t think this is the right way to solve this.
It doesn't matter what direction the two parts move. Their total momentum must be balanced by that of the third part.
Why not?
Oh. So this is right. Thanks again.
Can you verify my other post?
What post? Provide a link.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
