Boyant force on an immersed body.
  • Thread starter Thread starter Any Help
    Body Force
The discussion focuses on determining the buoyant force on a rigid plastic bead submerged in three different liquids, based on gauge pressure versus depth plots. The buoyant force is calculated using the equation that incorporates volume, gravity, and pressure. As the depth and gauge pressure increase, the buoyant force also increases. The participant concludes that the ranking of buoyant forces is a > b > c, correlating with the slopes of the pressure plots. The answer provided is confirmed as correct.
Any Help
The gauge pressure pg versus depth h is plotted in the figure for three liquids. For a rigid plastic bead fully submerged in each liquid, rank the plots according to the magnitude of the buoyant force on the bead, greatest first.
http://file:///C:/Users/user/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg figure here: http://www.transtutors.com/questions/the-gauge-pressure-p-g-versus-depth-h-is-plotted-in-fig-14-28-for-three-liquids-for--719045.htm
Buoyant force= Vgd + pgA------ (1)
p=pg + d.g.h ---- (2) p=pressure d=density of water g=gravity h=hight from surface
then as h and pg increases buoyant force increase according to equation 1. Then the highest slope represents the highest boyant. a>b>c
Is my answer correct?
Yes.
Likes Any Help
12K
15K
