- #71
Michael D. Sewell
You mentors take a lot of abuse, a big thank you to all of you for your contribution to the physics forums. -Mike
Bad idea - The main thing to protect is your head. Your legs are expendable. They can serve to absorb some shock albeit little. You might as well let someone take a full swing to your head with a baseball bat than lie on the floor. Ouch!Your best bet may to to lay flat on floor and adsorb the shock with as much surface area as possible.
Originally posted by outandbeyond2004
we have overlooked the effect of terror ==> adrenaline ==> superhuman athletic feats.
Absolutely NOT. If the elevator is falling at a constant velocity you can jump up and down on it all day long and not know that it is moving, it will seem as if you are on a stationary floor.jdavel said:Integral said:
"If you can understand the analysis I did up stream a bit you will understand why your legs will NOT be flexed for the landing following a jump."
I think I understand your analysis, but I think you've made some mistakes. For example, you say:
"With respect to the elevator we have y= 2t -gt2 = .05"
I don't think this is correct. In this equation, t refers to the time interval that begins when my feet leave the floor and ends when they are .05m off the floor. But during that time the elevator and I are both in free fall, so my speed "with respect to the elevator" is not accelerating at g; it's a constant, namely 2(m/s). So the equation to find t is just:
y = 2t = .05m
You are correct here, it is not a missing factor it is reading the wrong numbers out of my spread sheet. actually is is only a fall of about 3.5m which is survivable.Then you said this:
"According to my numbers you are .007s from hitting the floor traveling at over 8m/s, this equivalent to a free fall from about 12.5m."
I don't think this is correct either.
v(s) = sqrt(2gs)
It looks like you've dropped a factor of two somewhere; velocity should be more like 16(m/s).
Read my post for the correct numbers. Rember the elevator is falling at 10m/s so the impact speed is 8m/s I still maintain that the jump will do more harm because of the poor postion of your body at impact.I do agree with the 2(m/s) you used for a reasonable jumping speed. But that speed will come off your landing speed as long as you wait to jump until you're falling at a speed of at least 2(m/s). The problem is that 2(m/s) isn't very much, unless the fall is pretty short. Even from your 12.5m (about 40ft) you'd hit the ground at 16(m/s). A 2(m/s) jump cuts that to 14(m/s), better, but still pretty painful!
Most of what you say here is nonsense. I do not think your jumping will have any significant effect on the motion of the elevator. Keep it simple, treat the problem as that of a falling body, because that is what it is.The reason this problem got so complicated is that we all mixed physics with physiology.
I think the pure physics is this. Two masses are in free fall with one just above the other. The total momentum transferred to the Earth when both masses have landed, has to be the same, no matter what happens on the way down. If at anytime during the fall, the top mass can increase the downward speed of the bottom mass by applying a downward force to it, then the bottom mass will transfer more momentum to the Earth than it would have, so the top mass will transfer less and land more gently than it would have. It doesn't even matter when the force is applied (again, as long as applying it doesn't cause the top mass to start moving away from the ground).
I think the physiology part is this: The best survival strategy is to give as much of your momentum as you can to the elevator and then bend your legs so that the impulse, integral(Fdt), that you apply to the Earth is spread over the maximum possible time, thus requiring the minimum possible force. But if the fall is from more than about 50 ft, even doing both of these won't prevent a pretty serious injury.
outandbeyond2004 said:I apologize if I have offended anyone by anything like a poor choice of words or by the tone of my writing. Besides, my attempts to produce witticisms and amuse people were perhaps misplaced.
Jdavel,.Integral said:No we are saying that if you were falling at 60mph and jumped so your speed was 0 your body would be every bit as crushed as if you had let the ground stop you.
edit:
Forgot a bit.
Now let us suppose that the elevator is falling at a constant velocity.(I am going back to metric, just because.) Also I am going to totally neglect any superhuman feats, So the elevator is falling at a dangerously fast constant velocity, say 20m/s. If at some random time during the fall you jump up wards with an initial velocity of 2m/s your equation of motion wrt to the elevator will be given by y= 2t- gt2/2. You velocity will be given by v= 2-gt. The max height of the jump will occur when the velocity is 0 or at t= 2/g (let g=10 for easy numbers) so t~.2s. Now at the peak of your jump your velocity wrt elevator =0 at that point you begin to fall back to the floor of the elevator your velocity is still described by v=2-gt but now we have gt>2 so your velocity is negative. That is you are moving down.
Now let us superimpose the motion of the elevator on the motion of the jump. This is what an outside observer would see.
Velevator + Vyou = -20 + 2 -gt = -18-gt.
The first thing to notice that there is no value of t for which this is a positive number, so you are ALWAYS falling. For the time period (0,.2) your velocity will be less then 20m/s, at t=.2 your velocity will BE 20m/s (remember we have 0 velocity wrt to the elevator) for t > .2s you velocity will be GREATER then 20m/s as you will be accelerating in free fall motion until you reach the floor of the elevator. This would occur at t=.4s, at that time your velocity will be 22m/s.
OK, so there it is, during the period (0,.2s) you have succeeded in reducing your velocity wrt to the ground. Now, consider that you MUST be in the air when the collision occurs, the further into that initial .2s you are the faster you are falling, consider the condition of your legs at the instant you jump, they are fully extended, knees straight and perhaps locked, this looks like the way to MAXIMIZE injury, especially since you are still falling and will impact the ground before completion of the jump.
I still maintain that jumping will do no good.
It's not until your post #75 (out of around 100 in this thread) that we finally get this: "edit: Forgot a bit. Now let us suppose that the elevator is falling at a constant velocity..." (This one's my favorite. When did you remember to go back and sneak that in?)
