Calculate the amount of torque and power needed on an inclined plane
To calculate the torque and power needed to move a car uphill on a 30-degree incline, the force equation is established as f - mgsin(30) = ma, ignoring friction. The acceleration is derived from the equation vf = vi + at, leading to a = v/10. The discussion emphasizes the need to express the force in terms of torque and total work done. Participants are encouraged to clarify relevant equations related to torque and power. The calculations aim to determine the necessary parameters to achieve a specified final velocity within 10 seconds.
babol2728
Calculate the amount of torque and power needed to move a car uphill
from rest on a 30-degree inclination and reach a certain final velocity in time
less than 10 seconds
car wheel radius = r
mass of car = m
initial velocity = 0
final velocity = v
Torque = Force x Radius
Power = Work/time = Force x Velocity = Torque x Angular Velocity
I have calculated the force equation on the x-plane which is f - mgsin(30) - friction force = ma
and from the equation vf = vi + at resulting a = v/10
babol2728 said:
Homework Statement:: Calculate the amount of torque and power needed to move a car uphill
Relevant Equations:: State in variables
Per forum rules (Homework Help Guidelines for Students and Helpers) you must show some attempt.
Please also try to complete the Relevant Equations section. What equations have you been taught in connection with torque and power?
I have corrected my post
You are not told anything about friction, so ignore that.
From the above you can get an expression for the force. What torque does that lead to?
What total work is done?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
