Calculate the Capacitance given the Charge and Potential Difference
To calculate capacitance, divide the charge in coulombs by the potential difference in volts. The formula for capacitance is C = Q/V, where C is capacitance, Q is charge, and V is voltage. For conversion to picofarads, multiply the result by 10^-12. This method is correct for determining capacitance based on the given charge and potential difference. Proper application of this formula will yield accurate capacitance values.
member 757689
Find capacitance between two objects; one with charge +30 nC the other with charge -30 nC. Potential difference is 500 V.
C = Q/V
Hello, I would like some help on a homework problem. I would think that capacitance would simply be the positive charge's value in C divided by the deltaV value then multiplied by 10^-12 for pF conversion. Does this look like the right approach?
Yes, it does.
