Calculate the energy transferred given the voltage, current and time
  • Thread starter Thread starter GARV ARORA
To calculate energy transferred, the formula E = V * I * t is used, where E is energy, V is voltage, I is current, and t is time. The charge Q can be expressed as Q = I * t, which is substituted into the work done formula W = Q * V to derive the energy equation. For a potential difference of 10 V and a current of 2 A flowing for 1 minute, the energy transferred calculates to 1200 J. The discussion emphasizes understanding the process behind these equations rather than just arriving at the answer. Clear communication and adherence to forum guidelines are also highlighted.
GARV ARORA
New poster has been reminded to show more effort on their schoolwork questions
IF A POTENTIAL DIFFERENCE OF 10 V CAUSES A CURRENT OF 2 A TO FLOW FOR 1 MINUTE,HOW MUCH ENERGY IS TRANSFERRED ?
Q=I*T
its may be 1200 j but i dont understand the process
We know , W = Q*V (where Q is charge, V is potential difference and W is workdone ) this formula comes from the definition of Potential difference itself
Also, we know Q = I*t ( where Q is charge, I is electrical current and t is time ) this formula comes from the definition of current
Substitute the value of Q in the first formula , then W = V*I*t and since workdone is equivalent to energy transferred therefore, E = V*I*t
Putting in the values you can find your answer of 1200 J
Hope this helps
Ok , Thanks so much :)
GARV ARORA said:
Homework Statement: IF A POTENTIAL DIFFERENCE OF 10 V CAUSES A CURRENT OF 2 A TO FLOW FOR 1 MINUTE,HOW MUCH ENERGY IS TRANSFERRED ?
Relevant Equations: Q=I*T
:welcome: !
Please read our guidelines: upper case is considered shouting and in this case there is no need for that :wink:
In addition you should post your best attempt at solution before you are allowed assistance -- and merely quoting the book answer doesn't count.
Thread closed temporarily for Moderation...
Thread is reopened provisionally. @GARV ARORA and @Mohammad Ishmas -- please check your messages from me about your posts in this thread. Thank you.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
