Calculating CFM from 800 PSI Air Supply
To calculate CFM from an 800 PSI air supply through a 1-foot pipe, the velocity of air can be determined using the formula velocity = sqrt(2*Pressure/density). Given that 800 PSI exceeds the choke pressure for air, the maximum velocity is limited to the speed of sound, approximately 1115 feet per second. The flow rate in CFM can then be calculated using the pipe's cross-sectional area and the speed of sound, resulting in a CFM of 52,500. It's important to clarify whether the air is being released to the atmosphere or regulated to a lower pressure, as this affects the pressure drop and flow dynamics. Accurate calculations depend on understanding the system's specific conditions and requirements.
DaveA
If I have an unlimited air supply with 800 PSI and fed through a 1' pipe how do I calculate the CFM
I believe thie thread provides the answer you are looking for:
https://www.physicsforums.com/showthread.php?t=129961
In particular post #3:
Assuming no change in height, the pressure would be equal to 1/2 the density * (velocity of air) squared, or velocity = sqrt (2*Pressure/density) and flow rate equals velocity times cross sectional area, so cfm = area of pipe * sqrt (2*Pressure/density)
800 psi is way above the choke pressure for air, so no form of Bernoulli's equation will apply (that version is only good up to a few hundred fpm) and the max velocity is the speed of sound.
However, these questions almost always gloss over the issue of the outlet pressure: is this really 800psi air being released to atmosphere (an extremely unusual scenario) or is it being transported through a pipe to a regulator to use at 100psi? It is much more likely the actual pressure drop is only a few psi to deliver the high pressure air to a load...
...so we need more information about what this system is doing. Where is the air going?
If you are talking about air flowing only through a straight smooth (no friction) pipe then it would go a little something like this.
We can assume that 800psi is well above choked pressure as russ_waters has said. This means your air can only go as fast as the speed of sound.
speed of sound = sqrt(kRT) in this case I will use 1115 feet/sec.
We already know the diameter of the pipe so it becomes an easy problem.
CFM = pi()*(diameter/2)^2*(speed of sound)*(60sec/min)
CFM = 52500
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
