Calculating Current in a Coil: 50 Turns, 4.0 cm Diameter, R = 0.50
  • Thread starter Thread starter j88k
    Coil Current
The discussion revolves around calculating the current in a coil with specific parameters: 50 turns, a 4.0 cm diameter, and a resistance of 0.50. The original poster is struggling to find the correct answer despite providing equations and previous solutions with different values. There is a sense of urgency as the question is about to expire, prompting requests for assistance. Participants express confusion about the relevance of the provided solutions to the current problem. The thread highlights the importance of clarity in problem-solving and the need for accurate calculations in physics.
j88k
http://img520.imageshack.us/img520/1843/picture7j.png
for values 50 turn, 4.0 cm diameter, R = 0.50, surrounding 2.0 cm diameter, 20cm long, 200 turns, 60Hz through I_sol=(0.50A) sin(2πft) the solution would be:
http://img403.imageshack.us/img403/6412/picture2xwo.png
http://img22.imageshack.us/img22/7338/picture3cce.png
tried it a couple of times and I couldn't get a correct answer. Please help!
Isn't the point what are your numbers?
I'm not thinking the solution of another problem is going to need much help.
I'm not catching your point. I posted the solution to the same question but with different values to make it easier for people to determine the final answer to my values. If you can help then I'll be glad, if not then please ignore this thread. Thank you.
the question is going to expire in a few hours please help!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
