Calculating Flow From Tank to Impeller
  • Thread starter Thread starter imagine2014
    Flow Tank
The discussion focuses on calculating flow from a sewage pump drawing wastewater from a tank, specifically addressing the flow dynamics between the tank and the impeller. Participants clarify the flow direction, confirming it moves from the tank to the pump, and discuss the configuration of the suction line and standpipe. Key details include the standpipe's purpose for priming and air bleeding, the length of hoses involved, and the need for a clearer diagram to visualize the setup. Questions arise about the suction port's atmospheric exposure and the presence of a hose at the tank's bottom. Overall, the conversation emphasizes the importance of accurate diagrams and detailed specifications for flow calculations.
imagine2014
TL;DR Summary
Looking to calculate the flow through a slot in a pipe versus the overall flow
Wondering if someone can help me with the following.
If I have a sewage pump drawing wastewater from a tank, but there is a small distance between the invert to the impeller and the suction line, how much flow will enter through the opening, versus from the suction line.
Can anyone explain in simple terms how to do this or if there is an online calculator that will? Simple diagram attached. Not sure if the information included is sufficient to make a determination.
What is the flow direction on your diagram? I think its from the "blue tank" to the "trapezoid", but you have the "intake" labeled like its from the "trapezoid" to the blue tank?
Going to have to ask several questions to get you there.
hi,
Sorry for the delay. The flow is being drawn through the box outlet into the base of the trapezoid. Happy to answer anything else that might help. :)
So the flow is leaving through the top of the blue tank.
  1. the "T" labeled "3/4 inch suction port"; is the end without a hose open to atmosphere so you don't create a vacuum?
  2. Is there a hose inside the tank, running to the bottom?
  3. How long is the hose?
  4. What is the fluid?
There will be more questions to follow.
1. In the T, labelled 3/4" suction port, there is a standpipe that goes up a distance of 7-13' (depending on installation), which has a ball valve at the top. It is meant to bleed out the air to prime the pump initially, and after, it is closed and used as a cleaning port)
2/3. There is only the hose between the "Tee" and the Invert of the pump; and then from the outlet of the pump to the discharge of the tank that contains all components. Please note that all components are submerged, contained in a below-ground tank. The hose between the "Tee" and the pump invert is approximately 6-8' long, the hose between the pump outlet and the tank discharge port is approx. 15-20'.
4. The fluid is residential wastewater (sewage).
You're going to have to present a better diagram. There must be a line that runs to the bottom of the tank. Feel free to make another diagram or mark up this picture.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
