Calculating Volume & Work: V1, V2, W
  • Thread starter Thread starter miekier
    Volume Work
The discussion revolves around calculating the volume (V1, V2) and work (W) in a thermodynamic process. Initial calculations yield V1 as 374.145 m^3 and V2 as 160.703 m^3, leading to a work result of -35,988,000 J. Participants note that the negative work may indicate confusion between work done by the gas versus work done on the gas, as they are opposites. There is also a mention of the formula used, with one participant questioning whether "k-1" should actually be "1-k." The conversation emphasizes the importance of clarity in calculations and notation.
miekier
500 kg of O2 gas with a molar mass of 32 g/mol is compressed by a polytropic compressor with constant k = 1.3. Initial pressure is 1 bar, pressure after compression is 3 bar. The initial temperature is 15°C = 288.15 K. This process takes 50 minutes. Calculate the work done and the power.
P = W/t
p*V^(k) = constant
W = (p1*V1-p2*V2)/(k-1)
p*V = n*R*T
First i calculate n:
500000 g / 32 g/mol = 15625 mol
Then I calculate V1:
(100000 Pa * V1)/288.15 K = 15625 mol * 8.31 J/mol.k
so V1 = 374.145 m^3
I calculate V2:
100000¨ Pa * (374.145 m^3)^1.3 = 300000 Pa * (V2)^1.3
So V2 = 160.703 m^3
W = ((100000 Pa * 374.145 m^3)-(300000 Pa * 160.703 m^3))/(1.3-1) = -35988000 J?
I know my work is supposed to be positive, and the only value that can be wrong is V2 I think? Although that calculation seems fine to me, so I don't understand why the result for W is negative.
miekier said:
W = (p1*V1-p2*V2)/(k-1)W = ((100000 Pa * 374.145 m^3)-(300000 Pa * 160.703 m^3))/(1.3-1) = -35988000 J?
Not a familiar topic but in your equation "W = (p1*V1-p2*V2)/(k-1)" should "k-1" actually be "1-k"?
Also, it is good practice to give answer such as "35988000J" in standard form (scientific notation) rounded to an appropriate number of significant figures!
Well in our textbook the formula is listed with (k-1), but I can't find any similar formula online so I can't double check.
Although in the example problem the teacher uses the same formula and finds a positive value for W. That's what makes me think that my V2 must be wrong.
You're right about the scientific notation being better, it's just laziness with typing exponents that makes me not round them immediately.
At any rate, thank you for taking a look at the problem.
Any chance there's confusion between the work done by the gas and the work done on the gas? They are of course negatives of each other.
I think it might be correct, and you've just computed the work done by the gas, on the system. Which is indeed negative.
Steve4Physics beat me to it :)
Likes miekier and Steve4Physics
