PeterDonis
Mentor
- 49,154
- 25,216
David Byrden said:A superposition? Not a mixed state?
A superposition according to the many worlds interpretation. According to the MWI, the whole system is always in a pure state, but "the whole system" includes all the measuring devices and everything that interacts with them, including you. The pure state of the whole system is an entangled superposition in which each term is the product of matching states for each subsystem--the quantum particle, the measuring device, the filter, etc.
An "improper mixed state" is what we use to describe a portion of a system when we cannot know about the state of the rest of it (or even whether "the rest of it" exists, as we'll see in a moment). If you observe one particular measurement result from all this process--meaning, in your scenario, you see a stream of photons with one particular polarization coming from the box--then you "are" in one particular term of the superposition I described above, and since you have no way of knowing whether or not the other term (in this case there would be only two since the quantum measurement is only done once and has two possible outcomes) is there or not--there's no measurement you can make to tell--then you describe the system as being in an improper mixed state. That is what @Nugatory was describing.
The difference between the many worlds interpretation of QM and "single world" interpretations is that the MWI says the other term in the superposition is really there, even though you have no way of telling it is by making any measurements. Single world interpretations say that since you only observe one outcome, there is only one outcome; the other term isn't there.
David Byrden said:it was my understanding that if you have a photon in a superposition of two pure states of polarisation, it has - for all intents and purposes - a single polarisation which is their normalised vector sum.
The term "superposition" is ambiguous. You are using it here to describe an isolated photon, not entangled with anything else, whose polarization is a pure state that happens not to be one of the two basis vectors you have chosen for your representation. In this sense, all but two of the possible polarization states of a single isolated photon will be superpositions (since there will be only two basis vectors). So whether or not a state is a "superposition" in this sense depends on what basis you choose: for any pure polarization state of a single isolated photon, you can always choose a basis such that that state is one of the basis vectors.
But as I used the term "superposition" above, I was using it to describe a state of a total system that has multiple subsystems, all of which are entangled with each other. "Entangled" means that there is no way to write the state as a single product of pure states for each of the subsystems; the state can only be expressed as a superposition of multiple such product states. Whether or not a state is entangled in this sense is independent of your choice of basis. But a single isolated photon is not such a system; the minimal possible such system would be two photons (or two qubits more generally) which are entangled.
It's unfortunate that the term "superposition" gets overloaded in this way, but it does and you just have to be aware of that and use the context to determine which meaning is intended.
