Can I Use a Lead Acid Charging Circuit After a Boost Converter for Solar Panels?
Using a lead acid charging circuit after a boost converter for solar panels is feasible, but the output voltage must be adjusted to around 13.8V for effective charging. The discussion highlights that while the boost converter doubles the input voltage, it may be more efficient to connect solar panels in series to achieve the required voltage directly. Concerns are raised about the low current output in capacitor-based circuits compared to conventional inductor-based DC-DC converters, which typically provide higher current. The need for a switching buck converter is emphasized to maintain the necessary voltage for charging. Overall, optimizing the configuration of solar panels and the type of converter used is crucial for effective battery charging.
Hina Gohar
I am working on simulation and calculation of solar charge controller for lead acid battery..I simulated two solar panel in parallel along with switched capacitor dc-dc boost converter which is basically voltage doubler and it is working properly but now I need 12V on output of this boost converter to fed battery and dc load of 40W total..this boost converter every time provide double of input voltage while I need 12V constant for lead acid 12V and 100AH battery.One lead acid charging circuit is given in Boylestad Electronic Devices book my question is that can I use this circuit after my boost converter instead of load resistance..
Why do you voltage double parallel panels when you can simply use the panels in series?
To charge a 12V battery you will need closer to 13.8V with a negative temperature coefficient.
That 13.8V could be produced with a switching buck converter from two panels in series.
In this circuit I have seen current is very low.What's the reason that in capacitor based circuit current is low while in conventional DC-DC converter current is high in which inductor used as main energy storage element.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
