Can kinetic energy be added linearly?
Kinetic energy cannot be added linearly due to the principles of special relativity, which state that velocity addition is non-linear. The discussion highlights the relationship between kinetic energy and mass, noting that as velocity increases, mass also increases, which affects kinetic energy calculations. The relativistic kinetic energy equation, K.E. = (\gamma-1)mc², is referenced to emphasize the differences from classical mechanics. Participants encourage checking the math and considering frame transformations to fully understand the implications. Ultimately, the conversation underscores the complexities of kinetic energy in the context of relativity.
kbar1
According to special relativity, velocity cannot be added to another velocity linearly. But I was thinking, what about kinetic energy? K.E. = mv2/2. As velocity increases, the object's mass also increases. The way I see it, the increase in mass "compensates" for the less-than-expected increase in velocity (as predicted by classical mechanics). So am I right in saying, kinetic energy can be added linearly?
Does what I said above agree with relativistic K.E. equation: K.E. = (\gamma-1)mc2 ?
Have you actually checked the math?
This is the correct equation; so have you checked to see what happens when you transform between frames?
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 55 ·
  • · Replies 102 ·
  • · Replies 62 ·
  • · Replies 58 ·
