Can we design vehicle for animal self powered?
In summary, the idea is to create a land-marine vehicle that uses a horse as a power source. The horse would be harnessed using a system similar to a bicycle, and the vehicle would be able to travel at a speed comparable to a human on foot.
ThainaYu
29
Greeting. This is my first thread in engineering zone. Pleased to meet you all
As the topic said. I want to ask about how possible to make animal powered vehicle for animal
Or simply said, can we create bicycle for animal?
I just think that, Human walk is low efficient compare to bicycle. Even bicycle add weight into overall system. Using bicycle is faster and consume less energy than running
So, can we give animal the same kind of system? Some wheels connected to gear and... Pedal? Threadmill? whatever. Anything and everything that can boost harness power efficiency and lower fatigue of animal
I want to find some way to let human able to use animal powered engine instead of fuel. But just using direct drafting like the old day is not enough anymore. Boosting efficiency with mechanical engineering is my hope
Do you have any idea?
Thank you
Thank you. That seem promising but are there any really workable design for working animal?
I hope you realize that no matter how efficiently you get the little buggers pedaling, their steering will be atrocious.
Yesterday I have though the simple design maybe... The treadmill that slope and power rear wheels. The steering would be front wheels like normal car
Maybe design it like side bike. The steering is controlled by human. Just harness the power of animal
Also if we can train. Howabout... if animal tilt its body then it turn that way? Something auto calculate the center of gravity like Honda electric unicycle?
With the state of computer systems and control equipment, I suppose that anything is possible as far as the animal driving and steering the vehicle goes. What I do not understand, however, is how you plan to steer the animal.
In my idea right now...
Animal was on stand on the vehicle. And steering with the same as car steering system. Just take engine out and use animal walk on treadmill to power rear wheel instead
If we let animal ride this vehicle by themselves. Maybe train them to use it like we train ourselves to use bicycle
If we want to control vehicle. Then it would be another model that we sit on the side of treadmill and use normal steering wheel
Animal would stand on vehicle. Not touch the ground. Just harness their power
So what is the problem of steering?
How would a treadmill add any efficiency to the system?
Not to mention why you'd want to do this... Even if you somehow got an animal to use a device that made better use of their mechanical energy (which I highly doubt is possible or practical), the gains made in efficiency would be ridiculously overshadowed by the costs due to the complexity of the system as compared to having the animal simply tow you with its feet on the ground. I'm not saying give up, but maybe take a step back for a moment and reanalyze the problem.
I just guess that if we can add wheel to animal it would be more efficient to harness
But to add wheel directly would be too hard to control. So the treadmill is just medium, like human use pedal for bicycle, not pushing the ground by foot
Using treadmill would decrease efficient a bit but it would be more convenient to draw the power from animal to wheel. Which wheel and freewheel would increase efficiency in return. It could also add gear and other utility for decrease animal fatigue and strain
As I said at start. I guess it from the fact that we human use bicycle as the most efficient tool in traveling. Pedaling also able to harness human power for many mechanical task like grinding. Compare to working animal we use treadmill for the same engine
But I really don't have solid idea. Treadmill is just something come up to my mind. It can be anything that could increase overall efficiency than direct drafting
Dogs have been trained to run on treadmills to do tasks. I believe laundry.
As far as training the animal goes, I doubt it is possible. It is VERY possible to train them with a driver, but I doubt you could stick a dog in a self powered vehicle and say: "Ok Fido, go get the mail."
I have seen videos of a dog riding a skateboard and navigate corners very well. But it was all down hill.
Animal-powered hybrid land-marine vehicle:
One thought would be to have a wheeled supporting cart that fits under a horse and supports 50-75% of their body weight. As long as there was enough traction between their hooves and the road to be able to propel the horse and rider forward, the unweighting would make walking and trotting easier on the horse. The horse might even be able to be trained to "glide" by lifting its hooves off the road after getting to speed on the flats, or on downhills. The rider would control the steering and braking of the supporting cart.
Wonder what the horse would think of that -- no idea if it could be made comfortable for them. This would probably only work on smooth roads (maybe smooth dirt roads too...).
Walking is the most efficient tool in traveling; bicycling involves mechanical losses.
I don't think that's true, Danger. You can't coast while walking...
But you have to have built up momentum in order to coast, at a mechanical loss.
Bicycling is much more efficient than walking on a joule/km basis.
The catch is that it requires a reasonably level surface, whereas walking is much more flexible.
The power wasted in walking gets captured for forward motion by the bike.
The OPs idea is an interesting one and entirely feasible.
Here in NYC, many people walk aging pets with paralyzed hindquarters that are supported by a wheeled frame.
The concept could surely be extended to the entire animal, in line with berkeman's idea. Steering would work by flexing the carrier vehicle.
Horses are more difficult, they might have trouble breathing properly while suspended from a carrier.
Still, it would perhaps allow for much faster horses, just as bikes enable much faster humans.
I guess that therein lies the basis of my disagreement. I live in the foothills of the Rocky Mountains. There's no such thing as a level surface. Two of the hills leading to and from my town are 8% grades, and the third is 6%. One east-west road is fairly flat, but has a southward slope.
My mistake, I meant even rather than level.
Biking preserves momentum much better than walking does. That saves energy.
The calorie burn for walking is about three times that used for biking, according to this:
http://www.worldwatch.org/node/4057
Walking loses more mechanical. You build energy and lose most from break of foot touch the ground. The momentum you gain from pushing forward is just near half. Compare to pedaling and gear it loses too but less than walk
At least the kick scooter is more efficient than walk. Because the wheel draw power that normally lose from walk
Flexibility in most system come from efficiency drawback
All I can say with efficiency concerning biking vs. walking is how far do you think you can walk in a day compared to how far you can bike?
The only additional benefit to cycling over walking that I can see is gravitational potential. letting my weight propel the bike forward, or rolling down hill.
biking is faster,
biking is faster,
Are you able to walk 75 miles in a 10 hour day?
That is your retort speaking to the comparable efficiency of a bike over walking?
well then, no I can't walk 7.5 miles an hour since my kickers are only little, must mean the bike is more efficient...or is it more effective. Shoot! now I forget/
There is no question a bike is more effective at getting from a to b compared to walking.
So do you think it takes less energy for your body to walk X miles in Y hours than it does to bike X miles in Y hours?
Depends on how fast you ride the bike. Aerobic respiration is more efficient than anaerobic, around 16x more efficient, so if your ride is full of tough sections it probably will take less energy to walk.
I don't know :confused: I don't even know what x and y are...is x/y still walking?
all things idealized as favoring the bicycle, yes its more efficient; & vice-versa.
resting on the seat/handle bars probably reduces the energy used by a fair bit,
Well, some numbers may help to convince folks...
http://www.health.harvard.edu/newsweek/Calories-burned-in-30-minutes-of-leisure-and-routine-activities.htm
Walking at 4.5mph (pretty fast walk) burns 186 calories in 30 minutes (155 pound male).
Bicycling: 12-13.9 mph (not fast) burns 298 calories in 30 minutes.
186cal/4.5mph = 41.3 cal/mph > 22.9cal/mph = 298cal/13mph
So riding a bike easy is about twice as efficient as walking briskly in terms of calories divided by speed, or calories to travel a distance. :smile:
That is convincing! however, I suppose a brisk walk is not a very good control for seeing if bicycling is more efficient compared to walking. Still vague but perhaps a "casual" walk instead? :smile:
Presumably walking half as fast would burn about half the calories or more, so no help in improving efficiency...
yes well to your point about what is convincing :wink:
  • #31
You are grasping straws here to uphold a certain view. Of course you could say a tough trail would be difficult to bike. I could technically bicycle up several hundred stairs and obviously it would not be easy. This is not the point. I think the discussion is limited to what is reasonable to bicycle in the first place.
nitsuj said:
I don't know I don't even know what x and y are...is x/y still walking?
X is distance and Y is time in both the walking and biking scenarios. How much simpler do you want it? X is the same distance in both walking and biking scenarios and Y is the same amount of time in both walking and biking scenarios.
  • #32
And if we stand still, we burn no calories and die of hypothermia. :devil:
  • #33
:smile:
Watching TV still burns 28cal, so we are safe with some baseline. :smile:
  • #34
Right, so calories vs speed isn't linear to zero -- and I suspect not even linear at all.
  • #35
I'm not grasping at straws, just providing a salient piece of information. When riding a bike one ten to ride much faster than walking, depending on how efficient a bike is the level of effort to go that fast could include spurts of anerobic exercise which is less efficient. You raised the point earlier that you ride faster than walk. This is relevant.
