- #36
Dale
Mentor
- 35,904
- 14,387
I still think that this is wrong. When you are talking about experimental tests of SR you are necessarily talking about a test theory, the most common of which is the Mansouri Sexl test theory. In that theory the transform from the preferred inertial frame to any other inertial frame is given by:LastOneStanding said:So, George was right to clarify this point and, since you and PAllen both said he was wrong, I think I was right to explain why he wasn't.
[itex]t=aT+ex[/itex]
[itex]x=b(X-vT)[/itex]
[itex]y=d \, Y[/itex]
[itex]z=d \, Z[/itex]
Perhaps the OP should have asked if there were any experimental tests of the Mansouri Sexl parameter a rather than asking if there are any experimental tests of time dilation, but the synchronization convention adopted has absolutely no bearing whatsoever on the value of a. The synchronization convention is contained in e which is the only parameter which is not experimentally testable.
The value of the Mansouri Sexl parameter a is experimentally testable, it is not an artifact of the synchronization convention, and it is usually interpreted as time dilation. Therefore I think that it is incorrect to say "SR Time Dilation is not observable or measurable and cannot be tested, just like the one way speed of light cannot be tested." It is certainly not just like the one way speed of light in this respect.
