Can't remember equation for coefficient
To calculate the coefficient of friction, it's essential to relate acceleration to initial speed and distance. A free body diagram can help identify the necessary equations. The discussion emphasizes the importance of posting attempts for better assistance. Understanding terms like Fst and the equation Fn - Fg = ma is crucial for solving the problem. Utilizing available definitions of friction force will aid in finding the solution.
Arwing
A crate rests on a flatbed truck which is initially traveling at 17.9 m/s on a level road. The driver applies the brakes and the truck is brought to a halt in a distance of 45.6 m. If the deceleration of the truck is constant, what is the minimum coefficient of friction between the crate and the truck that is required to keep the crate from sliding?
Fst=ma, Fn-Fg=ma
We did a lab in class on how to calculate it but he collected it and its days later, can't remember how to attempt it.
Hello @Arwing ,
:welcome: ##\qquad##!​
Unfortunately we can't help if you don't post your attempt at solution (see guidelines).
However, you will need some more equations:
to relate the acceleration to initial speed and the distancce of 45.6 m​
to relate the coefficient of friction to some other variables in the problem.​
And: I have no idea what Fst is, or what Fn-Fg=ma means ...
You don't need to remember anything. You have the definition of friction force available everywhere and you have to do a free body diagram to find the equations needed.
Likes PhDeezNutz and hutchphd
