Car-Car System: Energy Conservation?
The discussion revolves around the feasibility of a car-car energy conservation system, emphasizing the application of energy conservation laws. It is established that the thermal energy produced during a collision can be calculated as mv², regardless of the reference frame used. The calculations confirm that the energy before and after the collision remains consistent across different frames. The importance of considering all energies involved in the system is highlighted, although the initial inquiry about reassurance indicates some uncertainty. Overall, the analysis provides clarity on the energy dynamics in a car-car system.
simphys
(I) Two railroad cars, each of mass 56,000 kg, are traveling
##95km/h##toward each other. They collide head-on and come
to rest. How much thermal energy is produced in this collision?
law of conserfvation of energy
this is an easy problem but would it be possible to consider car-car system. What I did on paper was carsystem and because they have the same properties(mass en speed) multiply by ##2##
solution for car-car-earth system I assume is the following if it is possible?
solution for car-car:
law or conservation of energy says:
##E_1 = E_2 + W_{th}##
##\frac12m_{c1}v_{1,c1}^2 + \frac12m_{c2}v_{2,c2}^2 = 0 + W_{th}##
massses same, velocity same so :
##W_{th} = mv^2 = 3.9E7J##
edit: What I actually want reassurance of is.. this is all dependent on the system and if we take car-car system we consider all the energies of the involved objects by examining all of 'em seperately. I am asking stuff like this because it's kinda important but not really mentioned only implicitly in the book
Thanks in advance
Edit: ;earth not included
It is not dependent on the frame. If the cars have velocities ##\pm v## in the cener of mass frame then the thermal energy produced is indeed ##mv^2## as you have concluded. If you instead consider a frame moving with velocity ##u## relative to the center of mass system then the velocities of the cars are ##\pm v - u## and consequently the energy before collision
W_0 = \frac{m}{2}[(v-u)^2 +(v+u)^2] = m(v^2 + u^2).
After collision the cars are moving at velocity ##u## and so the kinetic energy post-collision is
W_k = \frac{2m}{2} u^2 = m u^2.
The thermal energy produced is therefore ##W_0-W_k = mv^2##, just as found in the center of mass frame.
wow that's aamazinggg thanks a lot! I guess I don't need to ask such question then as I'll most likely encounter that soon myself
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
