Center of mass of an equilateral triangle (Kleppner)
The discussion focuses on finding the center of mass of an equilateral triangle with side length 'a'. The calculations for the coordinates R_x and R_y are presented, showing R_x = a/2 and R_y = a/(2√3). A suggestion is made to position the triangle's apex on the y-axis for easier calculations, which would yield R_x = 0 due to symmetry. Additionally, participants discuss the integration limits used in the calculations, clarifying the height as a function of x and the piecewise nature of the triangle's sides. The conversation emphasizes understanding the geometric relationships and integration involved in determining the center of mass.
geoffrey159
Find the center of mass of an equilateral triangle with side ##a##
## \vec R = \frac{1}{M} \int \vec r \ dm ##
## dm = \frac{M}{A} dx dy ##
## A = \frac{\sqrt{3}}{4}a^2 ##
I set a pair of orthogonal axis ##(\vec x,\vec y)## so that one side of the triangle lies on the ##x## axis, and one vertex is at the origin.
I find the following position for the center of mass:
##R_x = \frac{1}{A} (\int_0^{\frac{a}{2}}\int_0^{\sqrt{3}x} x \ dy\ dx + \int_\frac{a}{2}^{a}\int_0^{\sqrt{3}(a-x)} x \ dy\ dx ) = \frac{a}{2}##
##R_y = \frac{1}{A} (\int_0^{\frac{a}{2}}\int_0^{\sqrt{3}x} y \ dy\ dx + \int_\frac{a}{2}^{a}\int_0^{\sqrt{3}(a-x)} y \ dy\ dx ) = \frac{a}{2\sqrt{3}}##
Do you think it is correct?
That's the correct answer. It would have been easier to put the apex of the triangle on the y-axis: then, by symmetry, R_x = 0.
I did not think about that! Thank you!
Please let me ask: I think I understood why the upper term from integration interval is equal to x\sqrt{3}, is the height in function of x, but what is the idea behind the upper term from \int_0^{\sqrt{3}(a-x)} x \ dy?
What are the equations of the two lines, which intersect at the apex, forming the sides of this triangle?
Oh, of course, it would be something like a piecewise function where x \sqrt{3} if 0 \leq x \leq \frac{a}{2} and a \sqrt{3} - x \sqrt{3} if \frac{a}{2} < x \leq a. Thank you for your answer.
