B Centrifugal force spinning Basketball
Centrifugal force on water droplets on a spinning basketball is influenced by the ball's stippled surface, which helps retain droplets during rotation at speeds of 33 RPM, 45 RPM, and 78 RPM. The surface roughness and attraction between the droplets and the ball are strong enough to counteract gravity. At the equator, centrifugal force may lift droplets off the surface, but they remain stable due to surface tension and adhesion until speeds exceed 78 RPM. The discussion suggests that understanding the experiment's purpose could clarify the findings. Overall, the interaction between centrifugal force and surface properties is crucial in this context.
nick200000
Hi, Looking for Centrifugal force on water droplets on my spinning Basketball at 33 RPM, 45 RPM and 78 RPM
Welcome to PF.
It appears the stippled surface of the ball holds the droplets in position, so they do not move during rotation. Maybe drops stick to the worn tip of the bump or to contamination of the surface between bumps. That surface roughness, and attraction, is clearly strong enough to counter gravity.
A droplet near the equator or the pole will not be expected to migrate across the surface when the ball is spun. Near the equator, the force would tend to lift the droplet off the surface. But the rate of rotation, required to break free, would need to be greater than 78 RPM before overcoming the surface tension and the bond with the ball material.
It might help if we knew what you were trying to disprove with the experiment.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
