- #526
Aether
- 2
Each relevant event is time-stamped using a clock that is located nearby, and the travel time for each neutrino depends on how the clocks at each end of the experiment are synchronized.BobCastleman said:If you cannot measure the speed of light one-way, then how can you accurately transmit the information to the other end that signals the start time?
Yes, but they don't need to know this right away.If point A initiates an event, then point B needs to know the time of initiation.
In fact, the time-stamps from CERN are not immediately made available to the people at Gran Sasso. They only get to see that information after they have reported the time-stamps for the neutrino detections.Basically, the neutrinos arrive before the signal of the start time, since the signal is being bounced off a satellite, or sent over a fiber optic cable or some such thing and is not traveling at c.
Sure, its a tricky calculation for many reasons, but that's nothing that can't be dealt with given enough time and money.It must be a tricky calculation, seeing as both ends of the experiment are accelerated reference frames via the rotation of the earth. Wouldn't they they be under different accelerations based on their latitude and altitude? Wouldn't the entire path of the transmitted start signal also be subject to acceleration issues in the calculations? I assume they had to use numerical methods to do all those calculations. It would be ironic to find that the intrinsic errors in computerized floating point arithmetic caused the anomaly.
