Charge inside a spherical conducting shell
When a charge is placed inside a spherical conducting shell, the electric field within the conducting material is zero due to the redistribution of charges on the inner surface. However, the electric field in the empty space inside the shell is not zero. If a hole exists in the shell and the charge is moved through it, work is required because the electric field in that region is not canceled out. Conversely, moving the charge through the conducting material itself incurs no work since the electric field there is zero. The discussion emphasizes the distinction between the electric field in different regions of the shell and the implications for work and potential energy.
zeeva
If a charge is placed inside a spherical conducting shell, is the total electric field inside it zero? I am thinking that if the charge is positive, then the conducting shell will have an equal amount of negative charge on its inner surface, therefore the E field should be zero inside, right?
You mean the electric field in the space filled by the conducting material? In that case you're right, it would be zero. That's pretty general, actually: any space filled with conducting material will have zero electric field, because if the electric field were nonzero, it would push around electrons inside the conductor until they canceled out the external field.
Of course the E field in the empty space inside the shell would not be zero.
Does that mean that if the shell had a hole through it and we wanted to move the charge from the inner radius to the outer radius, the work would be zero?
It would be better to use energy considerations here. The value of potential energy would be different in the initial and the final configurations.
Work done=Change in Potential Energy
Not if you move the charge through the hole. The space of the hole is not filled with conducting material, so there's no reason the electric field inside it would be zero.
Of course, if you move the charge through the metal itself, and not through the hole, then the work done would be zero.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
