pb23me
- 207
Estimate the stiffness of a spring in a childs pogo stickif the child has a mass of 35kg and bounces every 2 sec.
x=Asin(wt)
w=2(pi)f
w=2pi/T
F=mg-kx=ma
U=1/2kx2
E=1/2mv2+1/2kx2
The equations that are listed are the only-harmonic motion- equations that I am allowed to use. This problem seems much more complicated to me than it appears.Am i supposed to use kinematics equations first, then subtract the time the child is in the air from the two seconds? Also the child is going to be in contact with the ground for some specified period of time while the spring is contracting, and rebounding. If i just think about it as simple harmonic motion then the period is 2 seconds. Then w=2pi/2 or w=pi then i looked at the sin graph and noted that at pi/2 v=0 so if v=0 at pi/2 then v=Awcos(wt) t=1 ... so at pi/2 on the sin graph the graph is at max height so i figured that the pogo stick was in the air so acceleration=9.8m/s2 then i solved for A using the equation a=-Aw2sin(wt) and got A=.993m...am i doing this correct? Isnt there a better way of doing this?
